I AM TRYING TO BORE SIGHT A REDFIELD 6 - 18 X 44 REVENGE SCOPE. BEFORE I CAN GET THE CROSSHAIRS ALIGN GOING UP AND DOWN I RUN OUT OF CLICKS ON THE ADJUSTMENT. I AM ABOUT 6 INCHES LOW WITH THE LASER ON THE BORE SIGHTER REACHING WHERE IT NEEDS TO BE. WHAT DO I NEED TO DO ?
SOURCE: can't adjust a Redfield Rangefinder scope
Found this info on another site a while back and saved it. Hope it helps! "the two lines across the top in your scope represents 18" which is the standard size for the deer's body from the top of his back to the bottom of his stomach. If you see a deer feeding in a field and you want to know how for he is, you turn your power up till the top of the deer and his stomach fit between the two lines at the top in your scope. You then
look at the scale at the bottom of your scope and it will tell you how far he is in yards."
SOURCE: i have a redfield 3x9 rifle scope and looking for tips on sightin
NO. TURN THE ADJUSTMENTS UP AND TO THE RIGHT!
