Question about Xerox ColorQube 9201P
Remove a hard drive from a xerox colorcube 9201
2 Suggested Answers
SOURCE:
  • 61 Answers
SOURCE: replace hard drive
You bought a new HDD?
Posted on Oct 07, 2012
How to remove hard drive in xerox pro 245 copier
Hard drives in printers? Never heard of such a thing. Memory maybe but not hard drives. Go to the Xerox website and enter your model and they should be able to help you. Unable to help with this one. Good luck.
Jul 06, 2014 | Xerox Office Equipment & Supplies
Xerox colorcube 8570 wont start
its crazy we just had one the other day that was acting up. If you have a spare control panel try switching it, look for any lights. If you know your control panel is 100% good. Then you might have to end up switching the power supply.
iteminconline
Nov 04, 2013 | Xerox Phaser 8200 Laser Printer
Xerox error code 093-559
On the ColorQube 9201 and 9300, this error says "Head 3 cyan reservoir did not fill within the correct time." This a difficult machine to service so you shouldn't start without full documentation and experience.
This code may require one of a dozen parts, most of which are expensive and challenging to install.
Good luck ...Whit at www.iteminconline.com
Sep 03, 2013 | Xerox ColorQube 9201 9202 9203 Cleaning...
Xerox ColorQube 9201 error code 093-559
The ColorQube is a big $20K machine that is rather difficult to repair. Hiring a professional is the best practice. Even so, being informed will assist your discussions with the technician.
This error tells us that a Cyan reservoir isn't filling up. There are many suspects, probably Purge Line, Ink Reservoir, or Printhead. If you want to repair it on your own, you will need a service manual, and tech support.
Whit
Item, Inc.
Xerox ColorCube 9201 fax output tray change
Yes. If you press the login key( admin : 1111) then hit machine status(left side) there is a tab on the touch screen that says tools. If you go under fax settings or default fax settings it will be a option labeled as output destination. You can also find these setting if you type in the ip address of the mfp in your web brouser (same user name and password required). Hope this helps!
Jan 04, 2010 | Canon LaserClass 2060P Plain Paper Fax
Xerox ColorQube 9201P Logo
233 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
