SOURCE: my moultrie 200 takes good day pictures but night
thats because there is not any light to take a pitcher in, i bet the flash is not working right...try the flash out first
SOURCE: moultrie D50 game trail camera won't take pictures in dark
Does the flash work? Could be flash circuit or day/night sensor.If you have another D40/D50 camera that flash works but has other problems,swap out the sensors.If not the sensor but the flash circuit then most likely one of the large charge capacitors which has to be soldered in.I use a digital multimeter with I/O capacitor test function..these caps should be about 250mfd.
SOURCE: moultrie I60 is only taking black and white pictures.
make sure you don't have flash turned off in menu...as you take a pic (use handheld mode)..see if rose colored lens shutter flips in front of lens(does so on daylight pics...may be hung...wire,ect. preventing it's movement.
