Depending on which thermostat you are talking about , the main oven thermostat is complete with with sensing bulb, so is replaced as a complete unit.
The other stats, including over heating stat, and cooling fan stat do not have a sensing bulb, they are a bi-metal device, and can be replaced individually.
You to check the element with a meter to ensure if you are getting a sapply to it, if you are, then the new element is faulty, if no supply, then probably ythe thermostat is faulty, also check for broken or bad conn ections.
the thermostat will need replacing , but only the way to turn off the oven if it doesnt have a main switch , is to turn it off at your main switch board of your house or unit, it will say stove or oven
Disconnect the element, and run the oven for at least 30 mins,,if it does not blow fuse, then more than likely it is a faulty element.
What I cannot understand is that you say the thermostat light is on after the fues has blown? I would have thought that the light would be not be on, if the fuse has blown.
If after replacing fuse and the stat is in the off position, and the indicator light is on then indeed the stat is faulty.
Plz rate my solution.
Thanks.
You need to replace a faulty main oven element.
This is done by removing the rear cover in the main oven,
there you will see the element, disconnect and replace.
It is not a difficult job , and is not too expensive.
Plz frate my solution.
THANKS.
Either teh grill element or the oven heating element is fault or the thermostat or grill regulator, locate which element is warm, if the grill then it is most likely the regulator, if it is the oven it is the thermostat.
Engineer
