Worked fine one day, next day, it won't start
Check the easy things first. Check your circuit breakers. Will a lamp or another appliance work when plugged into the same outlet? If it is plugged in and you wiggle the cord near the plug and near the vacuum will the motor try to run? This would indicate a faulty plug or cord. If the switch, plug or cord is bad, then you need an appliance repairman. Anything else is highly unusual and would probably require a new vacuum. Best of luck.
