Tablets & eReaders Logo
A
Anonymous Posted on Sep 22, 2014
Can I transfer photos from my tablet to my laptop.how ?
How do I transfer photos from tablet to laptop
asber
Level 3:
  • Master 296 Answers
  • Posted on Feb 15, 2015
asber
Master
Level 3:
Answers
296
Questions
0
Helped
159695
Points
1087
Answer is yes, and it is simple, connect your tablet to your laptop using your usb data/charge/link cable that comes with it, if your photos was stored on the default folder of your tablet which named DCIM (Digital Camera images), then a notification on tablet will show, pull the notification panel down (depends on the firmware), for some older firmware, pull them up, which is very near the clock on the right side corner, there is an information saying, tap for more usb option, tap it, it will lead you to usb option, select or tick PTP, go back to the home screen, from you computer, locate your galaxy tablet, (normally from my computer icon which has all the drives), double click it (make sure your tablet is not locked) select the DCIM folder, open it, select the pictures you want to transfer to your compter.
good luck.
peggyw1
Level 1:
New Friend:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Sep 22, 2014
peggyw1
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
6
Questions
Helped
599
Points
17
One way is to send via email.
  • peggyw1 Sep 22, 2014
    Open iTunes, connect your iPad. At the top of the iTunes prograam on your pc, click on the right side where you see iPad, it will bring up a summary of your iPad. Again along the top, click on "Photos", then you can choose to sync from OS of your pc either all or selected folders.
2helpful
Transfer photos from Proscan tablet to flash drive
put the flashdrive in your computer and plug your tablet into your computer and transfer them,or send them to yourself in emails
1helpful
Transfer photos from old Samsung tablet to hurdle
The SIM card will not have transferred any photos to your new device as the SIM does not contain this information. Did you move over some kind of memory card at the same time? If you did then that would be where the photos have come from. I can therefore only assume that the rest of your photos are on the device itself.
Best thing to do may be to plug the old device into a computer and transfer the photos to the computer and then back out of the computer into the new device.
How do i transfer photos from a usb to samsjng galaxy 3 tablet
To transfer files directly from a usb flash drive you will need a USB on the go adapter. If your tablet is rooted, StickMount will make the process much easier.
You can also use a computer to transfer the files, plug both the tablet and the flash drive into a computer and use windows to transfer them between the two devices.
Additionally you could use some sort of cloud storage to transfer them, attach the usb drive to the pc, and copy the photos to a service like Google drive or Dropbox, then simply download the files onto the tablet using that services app.
2answers
How do I transfer photos from eviant tablet to HP PC? The tablet plugs into the wall with no way to insert an end into my PC. The only way I've been able to transfer is thru email a few at a time.
The USER guide here http://www.qvc.com/Eviant-8-Tablet-w-8GB-Memory-Android-4.0-&-Google-Play.product.E223749.html
(Click on second set of red words below pictures to download. marked user guide in red.)
Shows you how to transfer files (photos) to your PC using a micro-usb to usb cable from your tablet to your PC.
3answers
How to put photos on my sd card
This more than likely means your internal storage is low and not the SD card and may not have anything to do with your pictures but more so with your apps. Go into settings and see if your tablet has the feature to set where your downloads and other media is stored, by default that will be your internal memory. change it to SD card or USB storage. In Settings you can also click on your apps individually and transfer them manually one by one to the SD card or USB storage or download a file manager and do so all at once. Some apps and files may not have the feature to transfer these apps the tablet came with or apps you downloaded that uses the internal memory. By default if a memory card is in you tablet pictures are automatically store there, if this is not the case the easiest way to transfer is connecting the tablet to a computer/laptop and transfer to the card or again use a file manager.
6helpful
4answers
Transfere photo from laptop to apple ipad
To transfer photo from laptop to iPad, follow this steps.
1. In the iPad management screen, click the "Photos" tab at the top.
2. Check the "Sync Photos" box at the top.
3. From the drop-down menu next to that, select the program or folder that contains your photo library.
4. Once all your settings are correct, click the "Apply" button at the bottom right corner of the iTunes window to sync again and add photos to your iPad.
5. Photos will consume space on your iPad, so keep that in mind as you select between syncing all photos and individual albums and videos.
6helpful
2answers
How do I download photos from my laptop (Toshiba Satellite) to my ipad?
To transfer photos from your Toshiba laptop to your iPad:
Step 1: Connect your iPad to your Toshiba laptop using the USB data cable that came with your iPad.
Download Install and run iTunes and select your iPad device from left panel under "Devices" section.
Step 2: Click on Photos tab, Check the "Sync Photos from" checkbox and select "Choose Folder..." option from drop-down menu. Locate the folder with the photos you want to transfer on your computer and hit "Select Folder" button.
Step 3: When folder listed in iTunes, select all pictures that you want to copy to your iPad and hit Sync/Apply button from bottom right corner.
1helpful
4answers
The PC on which I had itunes that synced with my ipad is no longer available. I want to transfer the music on my ipad to a new PC (with itunes). How do I do this transfer?
You can use iPad to PC Transfer, which can help you transfer from iPad to PC. iPad to PC Transfer is a professional sofeware, which can help you transfer Music, Movie, Photo, ePub, PDF, Audiobook, Podcast and TV Show from iPad to PC or iTunes library.
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
