Sylvania LC420SS8 two green blinks back to standby
These blinks [flashes] are fault indication (Error Codes).From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it.This will make repair easy.These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times.Count it carefully.If you wish to get some details, check the site linked here.It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given.Surf the site with patience.
SOURCE: Does not turn on.
i had my power supply blow on mine within the first year took it in because i had extended warranty and they fixed it, only problem was finding a dealer in my area to fix it, then took over a week, because of customer support issues
SOURCE: sylvania lc420ss8 lcd turned off wont turn back on
Simply unplug the set, let it sit for a minute or so, then plug it back in and turn it on. I had a similar problem with the same TV and it is working fine now.
SOURCE: WONT TURN ON
Most likely, the problem is a defective Main Processor Board. This is the board with the antenna, RCA and HDMI plugs. You cant repair or replace component parts on this board, so dont even try. You must replace the complete board. The TV says Sylvania, but it is a bloody Funia TV. Several years ago this foreign company bought out broke-azzz Sylvania . They are still carrying the Sylvania name since Sylvania was a popular TV name in the 70s. Every electronic company in the USA is now owned by the Chinese, so call Funai and order the part from them. Dont be surprise if they dont have a clue what the heck you asking for. America and all electronics have gone to the puddles. Do you know why? GREED.
SOURCE: There was a power surge and a loud pop and now the
A job for the technician on this one. I have only worked on several flat screen before, on my last days as an electronic technicians. Half of the ones I worked on was the power supply inside ir the problem was like this. Instruction on how to fix them would require me to write many pages on electronic theory so, I am very sorry It is almost impossible for me to help you on that. Be carefull where you take that tv to. some shop can't fix those. You may have to search your local area for someone who specialize in flat sreen HDTV. Well I hope I have shed a little light on the problem. Thanx for posting the problem.
SOURCE: my 32 in. sylvania power light blinks green &
Power board is dead,must replaced parts like capacitors puff up or burst open.Or replaced the whole power board.The websites Shopjimmy.com,Ebay.com have reburbish power board part.
