Bad control board?
SOURCE: i have a 199
It sounds like the heater element is going bad. It is located in the steel tube below the control box inside the access panel. Unless you are qualified to replace the element, better call in a pro. You can touch this tube while running the spa and see if it get warm.
SOURCE: Jacuzzi whirlpool, air on/off button on tub
If it is a air button that pushes in and comes back up, there is a good chance that the switch (which is mounted on the pump/motor) is bad. If the switch is a touch button on a key pad, the problem is in the control box for the pump/motor.
