2003 Accent Fender 3td56122s Hatchback, Driver Side, w/GT, GSi Tampa Or Ocala, Florida Logo
A
Anonymous Posted on Sep 21, 2014
My car is showing check engine on the dashboard whenever the engine is running
The dashboard is indicating check engine and the car was serviced but it still continues
crisencio manayan
Level 1:
New Friend:
  • Contributor 29 Answers
  • Posted on Sep 23, 2014
crisencio manayan
Contributor
Level 1:
New Friend:
Answers
29
Questions
6
Helped
5099
Points
49
You need diagnostic tools to see what is the problem of the car.. this illumination light (check engine) consist of electrical system and mechanical stability of engine and transmission..
2000 grand am gt. Check engine light is off but the Service engine soon light is on. There are no error codes. I have already changed the oil and reset the oil light.
Service engine soon ? Do you mean SERVICE VEHICLE SOON Indicator
The amber SERVICE VEHICLE SOON indicator is an alert to the driver whenever there are specific current codes stored in the BCM or in the event of a loss of Class 2 serial data.
If your vehicle has a check engine light ,it doesn't have service engine soon .One or the other .
2002 Ford Taurus will die several times while driving. When we get it to a shop, they say nothing is wrong. No indicator lights present on dashboard. What should we do? What question do we ask the...
Several things can cause engine to fail.
1. A malfunctioning car alarm
2. Magnetic coils
3. Short circuit especially on earth whenever you heat a hump power cut off
4. Fuel supply, dirty tank
5. Timing
6. Long overdue service
etc
1994 legend speedometer works once in a while
92 or 94?
is fuse 22 loose?
did the CEL lamp in dash glow at this FAILURE event
or S, D or D4 auto tranny lamps flash? BINGO,
did you look for ECU/PCM errors first.? that be first .
is the odometer dead? too, at same time?
on this car the VSS module (veh.speed sensor)
sends the speed data to 6 other modules. the speedometer is 1.
so of the other 5 are dead, its the VSS dead, if not its a bad speedometer.
on of those modules is the PCM, that runs the EFI engine.
so scan it, on this old car, you insert the diagnostic jumper
(service check conn.)
and read the flash codes from the CEL lamp in the dash.
this will show 17 error, VSS bad. if bad (its bad or bad conn)
easy huh?
log in to alldata.com and read the how to read OBD1 codes
it will be something like this. (photos missing)
When a fault is noted, the ECU (otherwise known as the ECM) stores an identifying code and illuminates the CHECK ENGINE light. The code will remain in memory until cleared; the dashboard warning lamp may not illuminate during the next ignition cycle if the fault is no longer present. Not all faults noted by the ECU will trigger the dashboard warning lamp although the fault code will be set in memory. For this reason, troubleshooting should be based on the presence of stored codes, not the illumination of the warning lamp while the car is operating.
All models are equipped with a service connector in side the cabin of the vehicle. If the service connector is jumped, the CHECK ENGINE lamp will display the stored codes in the same fashion.
The 2-pin service connector is located under the extreme right dashboard on Integra, Legend & 2.5TL; on Vigor models, it is found behind the right side of the center console well under the dashboard.
Codes 1-9 are indicated by a series of short flashes; two-digit codes use a number of long flashes for the first digit followed by the appropriate number of short flashes. For example, Code 43 would be indicated by 4 long flashes followed by 3 short flashes. Codes are separated by a longer pause between transaxles. The position of the codes during output can be helpful in diagnostic work. Multiple codes transmitted in isolated order indicate unique occurrences; a display of showing 1-1-1-pause-9-9-9 indicates two problems or problems occurring at different times. An alternating display, such as 1-9-1-9-1, indicates simultaneous occurrences of the faults.
When counting flashes to determine codes, a code not valid for the vehicle may be found. In this case, first recount the flashes to confirm an accurate count. If necessary, turn the ignition switch OFF, then recycle the system and begin the count again. If the Code is not valid for the vehicle, the ECU must be replaced.
and this warning
On vehicles with automatic transaxles, the S, D or D4 lamp may flash with the CHECK ENGINE lamp if certain codes are stored. For Legend this may occur with Codes 6, 7 or 17. On Vigor and Integra it may occur with codes 6, 7 or 13. In addition, the TCS lamp on NSX may flash with codes 3, 5, 6,13,15,16,17, 35 or 36. In all cases, proceed with the diagnosis based on the engine code shown. After repairs, recheck the lamp. If the additional warning lamp is still lit, proceed with diagnosis for that system.
I have a 2001 mustang bullitt that is showing service engine light on. Took it to mechanic and he put 2 different machines on it to show code for problem. No codes coming up and he can't turn off the...
There is a diagnostic procedure in the factory service repair manual for engine light lit ,no codes . Did you take it to ford dealer ? MIL - is referring to check engine , service engine soon etc...
  • MIL always on when engine is running (no DTCs):
  • MIL circuits
  • For Focus, Mustang, Town Car, Continental, LS6/LS8, Escape, Windstar, F-150, Expedition and Navigator/Blackwood:
  • Instrument Cluster, Section 413-01 of the Workshop Manual.
  • All Others:
  • GO to NB1
SERVICE ENGINE SOON indicator After the engine is started, the SERVICE ENGINE SOON indicator will prove out for a duration of three seconds. If the instrument cluster does not receive a message from the PCM within five seconds, the instrument cluster will illuminate the SERVICE ENGINE SOON indicator and log a diagnostic trouble code (DTC).
  • An indicator is inoperative/always on - SERVICE ENGINE SOON
  • Circuitry.
  • Bulb.
  • Instrument cluster.
  • PCM.
  • GO to Pinpoint Test P .
PINPOINT TEST P: AN INDICATOR IS INOPERATIVE/ALWAYS ON - SERVICE ENGINE SOON CONDITIONS DETAILS/RESULTS/ACTIONS P1 CARRY OUT THE INSTRUMENT CLUSTER SERVICE ENGINE SOON INDICATOR ACTIVE COMMAND Trigger the HEC active command MIL.
  • Did the SERVICE ENGINE SOON indicator illuminate?
Yes REFER to Powertrain Control/Emissions Diagnosis (PC/ED) manual.
No INSTALL a new instrument cluster; REFER to Instrument Cluster . CLEAR the DTCs. REPEAT the self-test.
1helpful
Alternator working ok but battery not charging
battery could be bad and so could alternator. can have both checked at local autozone at no cost to you....good luck
99 Lumina 3.1 L service engine icon stays on. How do I reset it?
There is a reason that the light is on. You should check to see what code or codes you have and go from there.
Volvo s80 2.9 auto 1999
you have a emission related code not a tune up /read the codes by volvo only then update your ?
Top Hyundai Vehicle Parts & Accessories Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Hyundai Vehicle Part and Accessory Expert? Answer questions, earn points and help others
