Vario perfect child lock setting is locked on
SOURCE: My Bosch washing machine (WFX145SGB
Eventually discovered that if the 'start' button is held down for a few seconds it unlocks the 'child lock'.
SOURCE: problem with child lock activated on bosch logixx
Most, but not all have a manual opening device located somewhere near the strainer or any other access opening on the Machine.
Just for furture reference, if you press and hold the start button for five seconds the "feature" should disable... hope this helps
SOURCE: key symbol showing
Power on, press the start button for 5 or 6 seconds, the sign will go
off. Try the door gently.
Pl rate me 'very helpful' for the free help, thanks
SOURCE: bosch excel 7 vario perfect
Methinks you really could do with a manual- for now and possibly later for other problems which may occur!
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
