Take out carrier box' full of engine oil
SOURCE: husqvarna chainsaw leaks gas when filling
HI. IT SOUNDS LIKE YOU MAY HAVE A PROBLEM WITH THE FUEL LINE, WHEN YOU TURN IT ON ITS SIDE THE FUEL MAY BE LEAKING AROUND THE SEAL ON THE FUEL LINE OR EVEN POPED OUT. ITS HAPPENED TO ME BEFORE. JIMBO
SOURCE: Cannot find adjustment oil screw on my Husqvarna 61 Chainsaw
The 61 has a 4 position oil pump, the adjuster is a black plastic screw located to the top right hand corner of the pump face, just behind the sprocket, you will have to clean around that area to find it. The pump has numbers 1 to 4 around the screw, 4 being the highest position.
SOURCE: husqvarna chainsaw 450 oil leak
The 450 has a very simple non adjustable pump, it sits through a black rubber pick up/delivery pipe, they are quite prone to leaking where the pipe sits up against the crankcase, the part no. of the pipe is 544084201, changing this will help, you can also try using instant gasket to seal it, you will need to remove the clutch , sprocket, and pump plate to get acsess to it.
