Konica minolta c451 code 2257/8 show cleaning brush motor,where is it located
SOURCE: Konica Minolta magicolor 2430DL
Open the top cover. Remove the drum (part with long green handle). Below the drum you will see a strip of glass about 4-5 inches long. Take a cloth and wipe across the glass.
This will normally clear up any white lines in your print.
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
SOURCE: What does trouble code C-2204 mean on our Minolta
this is a waste toner box error the waste toner box could be defective or the full sensor is defective i would start with replacing the waste toner box and clean the sensors on the door with some canned air the waste box and the sensors are located inside the lower front door the instructions on how to remove the waste box are on a label on the inside of the door
