I think i pretty much covered it id just like to know what other drain pumps from what other washers are compatable with my amana washer (nfw7200tw) drain pump (w10175948)
Make sure it a drain pump, they same will fit Samsung ,amana and Maytag, make sure it not just stopped up remove it and look at the impellers, i put one in to find out it was the water sensor was soaped up and telling the washer it was full when it was empty and i would get a nd on the front , no drain,Matt, need the answer to fix that let me know.
SOURCE: amana front load washer door locked with door open
To get the front off. (All screws look to be #2 Phillips Screws)
1. You have to unscrew (2) phillips screws from the back that holds the top on.
2. Slide the top off. (slide towards the back)
3. Then where the control panel is there is about 4-6 screws holding that plastic piece on, take those out this will allow you to pull the control panel up and out of the way.
4. At this point you can unscrew the 4-6 screws in the door area that holds the front of the washer on, once you unscrew those screws there is a tab that you have to lift the front over to pull the front off. This will allow you access to the locking mechanism.
5. There are only 2 screws holding te locking mechanism on.
