The brushes will nor rotate when I turn the power on.
SOURCE: bissell proheat 2x
Yes, there are belts for both sides, but if they look ok, then the brush motor may be bad. Brush motor part # 2036757 , right side belt # 2036804 left side belt # 2036688
SOURCE: I have a Bissell Upright Proheat 2x and the dual
Is there a light that comes on when you "turn the power on." If there is no light, and the unit is plugged in, how do you know there is current going to the motor? Sounds like there might be a break in the cord. Examine the cord near the plug end to see if one of the internal wires is broken. If you cannot tell, then you need to try taking the unit apart where the cord enters the unit and testing continuity with a meter.
SOURCE: Bissell proheat 2x carpet cleaner
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
Here is a tip that will give you all the information you need to fix your Bissell
Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
SOURCE: Bissell ProHeat 2x--brushes do not rotate; belts
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
heatman101
l
SOURCE: Brushes not rotating
heatman101
45wtw
