The pump delivers good pressure and volume for about 2 - 3 minutes then the engine begins to pulse and finally kills while I am trying to use the washer.
Hi pulsing is usually a sign of insufficient water flow to the unit.
always get the largest water hose you can for the feed and check to see if your water system can keep up (if it is a three gallons per min machine grab a bucket and make sure you are getting at least 3 gallons per min before you plug the machine in.
The number one culprit for bad flow is the ez hoses or retractable hoses.
SOURCE: engine keeps shutting down
Most Honda engines have an oil pressure switch that prevents engine damage due to low/no oil pressure. Make sure there is sufficient oil in the engine and that the wire is connected to the pressure switch.
SOURCE: Pressure washer with Honda GX160 5.5 HP OHV-Starts easily but...
what about the linkage between the governer and the carb. Is that working and not binding?
SOURCE: engine will not run but a few minutes at a time
Check your spark plugs, see if they are failing, if they are then your motor is getting to hot. meaning that you either have the fuel mixture set to high or the setting on the spark plugs are not correct causing you to burn hot.
Please rate
SOURCE: honda powered gx160 model pressure washer wont start
Did you drain out the fuel before you stock it? If you didn't, you may need to clean the carburetor or replace a new one because the fuel inside has become a kind of stick varnish. You may take a look at following link to see how to change or replace a carburetor. http://solosmallengine.blogspot.com
SOURCE: Gx160 Pressure Washer runs fine for 20 seconds Then shuts off
Check for stuck float, plugged fuel filter or fuel line. All tanks have a screen inside them to catch larger particles, and some also have a inline fuel filter. If everything checks ok, the passages inside the carb are plugged, follow the cleaning procedure outline in the manual to be sure you only have to do the job once! Take a look at following link to see more solution to different small engine problems. http://solosmallengine.blogspot.com/
