I need help to find the password for Netopia router so I can set up my Iphone with Wi-Fi access?
SOURCE: i can not remember my wi-fi password. i need it to
If you have tried the default passwords (blank, admin or sysAdmin) and they don't work, you will need to reset it back to factory settings. You can do this by finding a hole at the back of the unit and pressing the hidden switch there for a few seconds. After that it should be back to its original configuration. You will obviously have lost any changes you made to it since you took it out of the box.
SOURCE: I need to change my password to accesss wi-fi
username and password for accessing router is on a label on the router
usually admin admin
make sure the computer is connected via an ethernet lead to your router. Then open internet explorer and enter 192.168.1.1 into the address bar, then enter the username and password then choose advanced then wireless ,make sure its enables then choose security and write your key in
SOURCE: can you help me setting up a password for my wi-fi
How do I secure my network?
Log into your router using the "How do I log into my router?" instructions earlier in this article.
For more details, see
Securing Your Network: WPA+WPA2 (Recommended).
How do I change or reset my wireless network password?
Log into your router using the "How do I log into my router?" instructions earlier in this article. From the left-hand menu, select Wireless Settings from the Set Up section. Enter a new wireless network password into the Passphrase field under your security selection and click the Apply button to save your changes.
Testimonial: "good job!"
SOURCE: I'm unable to get my iphone to connected to
hi iv just this minute solved the problem its so simple you will laugh iv read through all these solutions which are complicated and none worked this deffo doesstep 1 look on back of your home hub at wap encyption security key thats what you got to type in when your phone askes you for a password dont type in your log in password ie roger 234..... type in code off back of home hub problem should go away
SOURCE: wireless g router network set-up
Follow this instructions:1. connect via hard wired connection using your PC (network cable)2. open your internet explorer or any browser.3. type the numbers 192.168.1.1 on the address bar4. you will be routed to your router's settings, type admin for USERNAME: and admin for PASSWORD.5. look for the basic setup/settings6. look for the wireless settings7. under your SSID comes the WEP or WPA-PSK option8. that is your wi-fi password, then modified it and remember the password you use for you will need to enter it on your pc when you are connecting via wireless connection.you can select ASCII for password. it should be alpha numeric or combination of letters and numbers.9. select save and apply. then you are good to go.
kindly rate this post.
