THE WASHER GOES THRU THE WASH And stops aND IE APPEARS AND WASHER STOPS AND IT WONT SPIN
SOURCE: I have WM1832CW washer. I
The error you are receiving is a bad water valve inlet problem. It's typically the cold inlet, but it's better to replace both.
Depending on the type of water you have, the valves could have lots of sentiment blocking the filter screens inside the valve, which can be cleaned, you'll just need to remove the water hose attached, and check.
If your valves look clear, then they have just possibly failed, and need to be replaced.
SOURCE: lg tromm washer what does IE stand for?wash
LG's 'IE' stands for (water) 'Inlet Error'.
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
