Question about Netopia Computers & Internet
What is the password for Wi-Fi on Netopia box?
I can not hook up to Wi-Fi because I don't know to password?
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 173 Answers
The password (a string of 26 letters and numbers) is usually situated on a sticker on the back of the box.
Posted on Sep 27, 2014
SOURCE:
  • 83 Answers
SOURCE: ipod touch
To connect to the router, you can change the wifi settings on the router by going to 192.168.1.1 in your internet browser and typing in the default username and password. If not, you can reset the router by holding down the reset button for 30 seconds on most routers.
Posted on Nov 10, 2008
  • 45 Answers
SOURCE: Bridging to a wireless solution
Get an Ethernet cable and plug it into both items. If you do not have a spare one, you might find one at thrift stores for very cheap.
Posted on Mar 18, 2009
  • 10 Answers
SOURCE: cannot connect to new wi-fi signals
Try removing all past connections , go to control panel , delete all your old settings and start new.
Posted on Apr 14, 2009
kakee
  • 1269 Answers
SOURCE: asking me for wi-fi password
The wifi password is the same as wireless network key (either WPA or WEP key). That's the same password that you used when you tried to connect to the wireless network using your laptop.
Posted on Apr 27, 2009
SOURCE: i can not remember my wi-fi password. i need it to
If you have tried the default passwords (blank, admin or sysAdmin) and they don't work, you will need to reset it back to factory settings. You can do this by finding a hole at the back of the unit and pressing the hidden switch there for a few seconds. After that it should be back to its original configuration. You will obviously have lost any changes you made to it since you took it out of the box.
Posted on Jul 02, 2009
My zte lever won't hook up to my home Internet.. Please help
This tutorial will explain how to get connected to Wi-Fi on your ZTE Tania Connecting your phone to a Wi-Fi network means you can access the internet, download apps and perform other tasks without incurring data charges.
This guide will show you how to get connected on the ZTE Tania.
How to connect to a Wi-Fi network
  1. From the main menu either swipe right-to-left on the touchscreen or press the right arrow button on the top right of the interface.
  2. Scroll through the menu and find the 'Settings' icon, then tap it.
  3. Press the button marked 'Wi-Fi'.
  4. Tap the Wi-Fi networking On/Off switch to turn Wi-Fi on.You'll then see a list of available wireless networks.
  5. Select the network you want to connect to.
  • If you selected an open network, your phone will automatically connect to the network. Note that some Wi-Fi networks, such as ones you might find in coffee shops, restaurants, or hotels, may require you to enter a password in your web browser before you can connect.
  • If you selected a secured network a password box will pop up. Enter the required password and then press 'Done'.
When you're connected to a wireless network, the wedge-shaped Wi-Fi connected icon appears in the status bar and shows you the signal strength - indicated by the number of bands that light up.
Unless you have wiped your phone, you won't be required to re-enter Wi-Fi details again as your handset should remember them.
How to connect to hidden networksA Wi-Fi network might be hidden, which means the network name isn't broadcasted. In this case, it won't appear in the list of available networks on the Wi-Fi Settings screen and a notification won't appear when the network is in range.
To connect to a hidden Wi-Fi network when it's in range, you'll need to enter the network name and password. Remember that the network name and password are case sensitive.
  4. Ensure that Wi-Fi is switched on.
  5. Press the 'Advanced' button.
  6. Tap the plus (+) icon.
  7. Enter the network name.
  8. Press the 'Add' button.
  9. On the 'Sign In' screen, enter the password, then tap 'Done'.
How to disconnect from a Wi-Fi network
  4. Tap the Wi-Fi Networking On/Off switch to turn Wi-Fi off and disconnect from the wireless network.
Alternatively, you can also press and hold the network name and then tap 'Delete' to disconnect.
However, bear in mind this removes the security settings if it's a secured network, meaning you'll need to enter them again next time you reconnect to that Wi-Fi network.
http://www.knowyourmobile.com/products/15952/guide-how-connect-wi-fi-zte-tania
Apr 05, 2016 | ZTE Cell Phones
Do these have a wps button?
Honestly, no idea. If you don't have a manual with the MODEL you can try to look for the proper one,
I got some links, maybe one is yours:
http://www.netwood.net/support/manuals/Netopia-3347W-ENT_qsg.pdf
http://www.netwood.net/support/manuals/Netopia-2247-62-User-Guide-US-EN.pdf
http://videos.cctvcamerapros.com/pdf/netopia-router/Netopia-Router-Manual.pdf
There are more....
Now, take note that WPS is too easy to hack. Read some about this issue:
How to Hack Wi Fi Breaking WPS PIN to Get the Password with Bully
And read more about theme...
Aug 26, 2015 | Netopia Computers & Internet
Wii-fi will not turn on
Let me know the device you are using
Jul 13, 2015 | Google Android
I need help to set up my Iphone with Wi-Fi access. Where and how to find my password for Netopia router?
Netopia routers use as default the following passwords:
1234
admin
password
Sep 20, 2014 | Computers & Internet
I just bought a Lg optimus L7 l don't know how to
Turning Wi-Fi on and connecting to a
Wi-Fi network
1 Touch > Apps tab > Settings >
Wi-Fi from the WIRELESS & NETWORKS
2 Set Wi-Fi to ON to turn it on and start
scanning for available Wi-Fi networks.
Tap Wi-Fi menu again to see a list of
active and in-range Wi-Fi networks.
• Secured networks are indicated by a lock
icon.
4 Touch a network to connect to it.
• If the network is open, you are asked to
confirm that you want to connect to that
network by touching Connect.
• If the network is secured, you are
prompted to enter a password or
other credentials. (Ask your network
administrator for details)
Feb 03, 2013 | Cell Phones
Connecting a genbook to wifi
Turn on your computer and locate the Wi-Fi icon.
This is located in the system tray in the bottom-right corner of the screen.
The icon looks like a series of rectangles that increase in size from left to right.
Right-click the Wi-Fi icon and select "Connect to a network." You will see a list of available wireless networks.
Choose a Wi-Fi network you want to connect to and select "Connect."
Enter the password into the password text box if a password is required. If a password is not required, you will automatically connect to the Wi-Fi network.
Click "OK."
Oct 11, 2012 | Computers & Internet
How to get a connection of WI fi when we don't have a password for it?
Why don't you have a password for it? If it's coming from your router you should know the password. If it is not coming from your router, then you are out of luck.
Apr 24, 2012 | Dell Computers & Internet
The ethernet and internet lights all light up when i plug in my router, but not the power light. I was about to go out and buy a bunch of ethernet cables to hook up the home computers, but don't want...
Dosn't the router come with cables? Connect one computer to the router and see if it works.
If the router is brand new and hasn't been set up yet, it may have open wi-fi working right out of the box without needing a password. In that case, you could use a computer or tablet that has wi-fi, and no need for an ethernet cable.
Nov 27, 2017 | Linksys Wireless-N WRT150N Router
I got wifi connection in several places, but why, when I turn off the 3G connection from the cellphone provider, I cannot use the internet connection I got from wifi. What do I need to change in the...
These days each WI FI connection has a password which you have to feed to gwt connected to that particular WI FI connection. So please get the password if you want to get hooked to a particular WI FI. You cannot get connected to any Wi Fi.
Jan 21, 2011 | Computers & Internet
Netopia 3347nwg wifi locked!!!
Hello michael,
The lock you see indicates that the network you are trying to connect to requires a password for authentication.
You can access your ipod settings and enter the credentials by following the below steps:
1- First connect to your closed Wi-Fi network
2- Choose Wi-Fi, then tap Other and enter the network name.
3- Choose Security, tap the type of security the network uses, and enter the password.
This should be it.
Have a good day.
Mar 15, 2009 | Netopia 2247NWG-VGx Wireless Router...
Computers & Internet Logo
63 people viewed this question
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
marty morrison
marty morrison
Joe Goldman
Joe Goldman
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
