Cooktops Logo
A
Anonymous Posted on Sep 20, 2014
How do I remove a main top for frigidaire gas stove model FFGF3047LSE and replace with a new one?
I purchased a cooktop because the other was dented.
  • Official Brand Answer 2,267 Answers
  • Posted on Sep 25, 2014
Frigidaire
Level 0:
Answers
2267
Questions
0
Helped
1289997
Points
2557
Hey friend, thanks for your post!
I understand that you want instructions on how to remove the main cooktop on your Frigidaire range, FFGF3047LSE. Some of these parts require precision and patience when replacing the exchange of such components or removing them from your appliance, I always suggest seeking professional assistance. One must be very careful as these replacements can lead to potential harm. -Matt
5 Related Answers
A
Anonymous
  • Posted on Feb 20, 2008
SOURCE: gas cooktop vent code
planning to install a 30" stovetop natural gas.need to know if i need a vent to the outside, it has 4 burners
Anonymous
  • 413 Answers
  • Posted on Jul 05, 2008
SOURCE: stove top dual infinite switch
If the new switch is a substitute, should have come with instructions.
If no instructions, I would suggest matching the markings on the switch next to each terminal.eg, match terminal marking on old switch as L1 to marking on new switch as L1. The markings are industry standard and should match from old switch to new switch.
If you need further assistance, let me know
Regards,
reg501
gerbee gomez
  • 222 Answers
  • Posted on Nov 18, 2008
SOURCE: auto electric lighter for the gas stove no longer works
gud day,the problem is ur igniter ligther is totally damage & nid to replace, if u want to use ur cooktop use matches or ligther every time open ur gas cooktop,tnx gerbee
Anonymous
  • 530 Answers
  • Posted on Jan 18, 2009
SOURCE: Romvoing the top of my Whirlpool Cooktop
well usually you have to remove the knobs. thentake all of the caps off of the burners. sometimes there are scres that hold the burner caps on. make sure you turn the power off. Then after you have done this the glass should come right off. If not there may be screws under the cooktop. Do these first steps and let me know how it goes.
Anonymous
  • Posted on Mar 18, 2009
SOURCE: Looking for new spare parts Creda Gas cooktop 42320
Contact this gentleman: Sandor Horky [email protected]
He helped us with parts we needed for our CREDA Model GGH110. I believe the company ADCO is the after market people for CREDA. Good Luck. PA Fi.
How to remove the stove top on frigidaire stove model FFGS3025PS
IF you open the door to the stove, you will see screws under the lip of the cook top, take those out, check the back of the stove for screws and then lift the cook to. On some models you may have to remove the sides of the stove too.
How do you remove the control panel on a slide in glass top frigidaire stove model CFES367DC2
Hey Tamara webber, thanks for your inquiry!
I see that you would like to remove the control panel on your Frigidaire range, CFES367DC2. . Regrettably, this is not a simple DIY job. I would highly recommend reaching out to an expert technician to ensure the appropriate replacement part is ordered and is installed correctly to prevent future issues. I hope this information helps to some degree and please do not hesitate to reconnect. -Matt
How do I adjust the flame on a MGC5430 gas cooktop? Flames are too yellow and cause black soot on bottom of pans. Doesn't seem to have an air shutter adjustment
Is this unit set up for natural gas or propane? New stoves usually come with ORIFACES for both gasses. They would install between the on/off knob and the burner tube under the stove top. They may be tapped to the under burner area of your stove. If you lift your top stove cover you may find them. If you don't find them, you may need to purchase the correct applications for your stove. GOOD LUCK FRIEND.
Top main burner want turn off
Switch is either bad in it or has food/grease build up not letting it shut off.
Unless its a newer model and is push button?
How do you remove a 318223634 glass top frididaire
Good Afternoon Leslie, this is Z. Thank you for your post!
I see you are looking for information on how to remove the glass-top of your Frigidaire Cook-top (318223634). It appears above-listed model number is invalid; however, this is not a typical DIY job. I would strongly recommend connecting with a professional to narrow down the precise issue before investing in parts that may or may not be the root cause. You can often locate a qualified service provider through the manufacturer website. Best regards.
Looking to replace a broken glass covertop for a Magnetic Induction hob
I looked up your cooktop and discovered it to be made by Frigidaire.
Hence & therefore, try the website "searspartsdirect" and see of they will give you schematics to buy the parts for your needs.
God bless your efforts.
I have a frigidaire ceramic cooktop. It started making a "popping noise" and there was a burned smell, but the stove was not on. I had to turn off the breaker to stop this.
Either there's ashort in the stove top or the wiring going to the appliance. Sorry but I would have to see it to see exactly how to fix the problem. the top needs to be removed and inspect the wiring to it. Test the top with a voltmeter forshorts.
1helpful
Hi my name is Ursula I have a 5 burner ceramic cooktop whirlpool model 005 and two of the elements do not work at all. How do I get this replaced or must I purchase a new stove top.
YOU DO NOT HAVE PURCHASE A NEW ONE , TAKE NOTE OF TYPE OF ELEMENTS AND ,I E LARGE/ OR SMALL, AND MODEL NUMBER AND CONTACT SUPPLIER FOR REPLACEMENTS, THEN YOU CAN TAKE OUT BROKEN ELEMENTS AND REPLACE WITH NEW ONES.
Top Cooktops Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Cooktop Expert? Answer questions, earn points and help others
