Samsung Galaxy Tab 2 Logo
A
Anonymous Posted on Sep 20, 2014
There is an x on my battery icon..What does this mean?
Also when I unplug my charger it shows that its still charging
CCervantes
Level 2:
Habit-Forming:
New Friend:
  • Expert 77 Answers
  • Posted on Sep 25, 2014
CCervantes
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
77
Questions
Helped
10623
Points
108
The x suggests that your cable is not charging the tablet. Double-check the cable or use a different charging cable.
My Samsung Tab A10 with S pen is charging slowly,even with Original charger,what may be the problem and how yo fix it?
I agree with Tom, you probably need to change the battery.
Don't forget that with modern rechargeable batteries, particularly in computers, phones and the like, it is not good to leave them plugged in to the charger all the time. This definitely reduces the life of the battery. Try a new battery, charge it up and then unplug the charger.
I know it's a bit more bother, it means having the charger ready to plug in when the battery alert light comes on, then unplugging it again when full. If you get into the habit, it is well worth it, given the price of batteries!
1helpful
My Tablet is on charge and the screen icon shows it is charging but the Charge % Icon is staying the same
Try a different battery charger.
Maybe you are using a battery charger of a phone.
They have the same plug but different Amperage.
Usually tablets have more powerful battery charger than phones (2.1A instead of 0.5/1A).
The battery charger that you are currently using seems to have enough power just to keep your tablet alive, but not enough to charge it.
You can check on the data written on the battery charger's body the maximum amperage.
2answers
I have a Mach Speed JLAB tablet. It wont power on. Just showes battery with exclamation point in the middle. Why?
That symbol usually indicates the battery isn't charged or charging. It could be a connection problem, a charger problem, or a battery problem.
If you have an extra wall charger, try that first as they don't always last forever. Make sure the plug that connects to your tablet looks clean and not corroded.
If it still won't charge, then chances are the battery needs servicing to make sure the connection is OK or the battery just might need to be replaced.
My Kindle will not charge
Here's a possibility, I just plugged in my Kindle Paperwhite using the Kindle charger and USB cable. It wouldn't charge.
I kept it plugged in all afternoon and it accepted no charge although it showed the little lightning bolt on the icon suggesting it was charging.
I unplugged the charger (it has two prongs) and reversed it so
the logo was on top and, Lo and Behold it charged. It could be the plug is not omniidirectional (i.e. it is polarized)
Digiland tablet won't charge. Is there a way to
Depends upon exactly what's happening.
  • When you plug in your charger, does it try to charge the Tablet? ie Does the Charging icon come on the screen briefly when the charger is plugged in with the Tablet turned off, or does the little charging 'lightning' symbol come onto the battery icon on the home screen when the Tablet is running?
  • I assume the battery has gone flat, but will the Tablet turn on when the charger is connected?
If the charging icon comes on, and/or the tablet will run on the charger, then both the charger and the charge port connection on the Tablet are OK, and the most probable cause of failure is the internal battery which will need to be replaced.
However, If neither the icon comes on nor the Tablet runs on the charger, then either the charger has died, or the plug/socket on the Tablet where it connects is faulty. The most likely cause is that the charger has died and will neeed to be replaced
There is a slight chance that the internal charging circuits in the Tablet may have developed a fault, but that is highly unlikely {:o)
2answers
Kurio 7s won't charge
Is it turned on when in charger. May need to be turned off before you plug it into charger Then it should show a battery icon on screen showing it is charging ..
2helpful
Why does the battery level icon show only a "lightning strike" symbol?
Lightning Strike Symbol means that the battery is charging.
If it is shown even when it is not charging then your charging circuit needs to repaired. Just replace the charging IC not a very high cost. Might cost around 5-10USD.
My Samsung galaxy tablet 7.0 died out while im playing a game, when I tried to recharge it a battery icon with caution sign show up. It does not recharge anymore. Tried another charger of my other Samsung...
Connection on tablet from charger to battery is not being made and that is why it is not charging in one unit but charging in other. Till problem is resolved charge battery in other working unit.
Top Samsung Tablets & eReaders Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
