For the first time in 16 years this normally reliable saw on start up it would race wide open and die if trying to attain idle speed plus it would run erratic. Carb needle looks good. I believe the carb is original. My action step now is to buy and install a carb kit. I did not soak the carb with cleaner.
Have you checked the impulse hose ?
Please see my detailed post on 021,023,025 impulse hose .
I have found that replacing the carb. with a new one . Usually between 27.00 to 38.00 dollars usually saves a lot of time over installing a kit. problem is usually due to a jet problem or the ethanol in the gas has removed the coating on a plug inside the carb. which requires carb. replacement
SOURCE: stihl 025 starts but cuts out have replaced spark
check the spark arrester screen in the muffler. if they stop up it will run like it has
no power and will stall
SOURCE: missing 025 Stihl chainsaw part
Hi, you are correct it is the tank vent. Go to a stihl shop and purchase a new one, regards Phil.
SOURCE: stihl 066 leaks gas out bottom of carb
Hi, you have a hole in the pump diaphragm in the bottom if the carby. Regards Phil.
SOURCE: Stihl saw runs but won't idle.
The paper pumps get stiff and do not pump fuel very well. It's the new Ethanol gas that is the Carb Killers. You need a rebuild kit not just disassemble and clean.
You have IDLE ADJUST Low Speed adjust and High speed adjust. Low and High speed adjust have nothing to do with Idle.
