Krups KM7000 Logo
A
Anonymous Posted on Sep 20, 2014
Beans not grinding on krups coffee maker?
Grinder not working
5 Related Answers
Pierre Laplante
  • 2061 Answers
  • Posted on Feb 08, 2008
SOURCE: Krups Orchestro Dialog coffee machine
that mean no coffee go through us if you dont use the machine often you might have coffee residue on the grinder teet remove the coffee bean in the hole were the coffee bean goes use a brush and clean the grinder teet very good with the residue of coffee gonna grind and gonna go through thanks for usig fixya pierre
Anonymous
  • Posted on Jan 27, 2010
SOURCE: Krups XP9000 fully auto unit will no longer grind
Perserverance...it's cheaper.
Also found a limit switch which i think is thermal so once removed the grinder is operational again!
Anonymous
  • 22 Answers
  • Posted on Jan 31, 2010
SOURCE: A Krups KM7005 coffee maker/grinder doesn't heat or drip water .
Mine had the same problem ... all the lights are on, grinding works fine, but no heat on the plate, and no dripping of water.
After a weekend on the workbench, I mastered this machine. The KM7005 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. To date, I have helped 13 people on this site fix this exact problem.
I'll be happy to advise you to fix this, or fix it for you. Write me at [email protected].
paul_on_trav
  • 17 Answers
  • Posted on Aug 14, 2010
SOURCE: I have a 12 month
You need to open the machine which is easy see my other post on leaking krups xp7240. The grinder can be taken out by removing two torix screws. Probably the electical brushes are gone. Take the grinder engine to a repair shop where they replace them.
Anonymous
  • Posted on Oct 29, 2011
SOURCE: My Krups xp7225 suddenly stopped
xp7225, the grinder in possibly plugged at the discharge,
you may have to remove the grinder to get it cleared-when doing so check the O-rings on the top plunger.
to disassemble start by removing the front trim. this is TRICKY, pull out a bit at the bottom and slide up at the same time it should release and you can access the shrews and remove the top, OYA remove the water tank and bean bin!
then remove shrews on top including under the the grate and the piston has a spring a the discharge shoot gently move it wile removing the 2 shrews holding the grinder in place, you may be able to gently lift the grinder up. wires are a bit long, place a rag or paper towel at bottom of pocket to prevent anything like shrews from falling though and you can remove the motor from the grinder by removing the shrews under it with a stubby shrew driver. BUT if the wires will not pull out enough..THEN you have to remove the sides and back.. remove by taking out the screws at the front and top leave the bottom and front in place..slide the back and sides together away from the back.....
open the cover over the wires MARK and record all wire positions unplug the the wire to to the grinder follow wires to find them.....if you have to untangle by removing the board USE CAUTION the connections are FRAGILE...up the spade connections first then lift the top of plastic and pull the board out and away!!! BE SURE TO NOTE WIRES there is ON wire diagram available !!!!
reverse to put things back together... GOOD LUCK
What do I do when coffee beans not getting to grinder
They cannot "not get to" the grinder, the hopper is mounted directly above the grinding teeth. The grinder is probably blocked and you will need to remover the housings and take out the grinder for cleaning and inspection. Most common cause of grinder blockage is dampness inside the housings from a leak somewhere inside the machine.
1helpful
Grinder in Krups Espresseria EA8000 stops and whirrs.
Hi, i had similar problem on my Krups. Inner star plastic part which remove powdered coffee is maybe damaged. You need to replace or overhaul your grinder or you can replace inner star plastic part by yourself. Coffee grinder spare repair part plastic inner star Krups Mhle...
No coffee is coming out of the machine...
in our machine we wanted a stronger coffee so we adjusted the auto grinder (where the coffee beans are housed) to the finest setting thinking the finer the grind the stronger the coffee...after doing this the machine wouldnot make coffee...we sent it away while still under warranty and the tech said that the grind selection was too low so they just turned the grinder back up a notch and it worked fine ....dont know if this will help but it's worth a try!
Grinder starts up but wont grind..nothing happens. one week old
I think this might be because no beans have gone down into the mill. There is a definite difference in sound when it is actually grinding beans. Try emptying the beans out, set it to the coarsest setting, put the beans back in, shake the thing a bit then turn it on.
Fill out water
The Krups Burr Grinder GVX2 featured in the picture is not a coffee maker, per se, it only grind coffee beans to use in other coffee makers. It is a lousy machine, and I would recommend returning it or not buying it.
DO NOT PUT WATER INTO THIS MACHINE. It will cause electric shock.
2answers
Grinder says no coffee beans after grinding, why?
does it realease the grinded coffe beans in the dregdraw with out using it?
if that is the case it a very small electricboard on the grinder that has stoped working or the connecter has fallen of from it.
I have a 12 month old KRUPS XP7240 coffee maker. It has just ceased to grind the beans. I suspect that the grinder or hopper to the grinder is blocked? Any suggestions how it might be...
Coffee will no longer grind.
ONE COMMON PROBLEM IN THIS MACHINES, SINCE THEY ARE MADE IN CHINA, THE QUALITY OF THE BEARINGS DETERIORATE IN ABOUT EXACTLY ONE YEAR. AND THE GRINDER NO LONGER WORKS. THE BEARING BUSHING ITS MADE OF BRASS, AND THE LOAD OF THE COFFEE BEANS OVER KILL THE BEARING. ITS A RIP-OFF....
Top Krups Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Paul Carew
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
