The chain is off.
You need to loosen the nut on the side of the chainsaw and then take the cover off. Remove the bar and take the chain off. Then put the chain back on the bar being careful about the direction of the chain. Place the chain back over the sprocket and lower the bar back onto the plate making sure the hole lines up with the adjusting mechanism on the cover. After you line up them up put the nuts back on and loosely tighten them. Adjust the chain where it is almost tight and then tighten up the nuts.
SOURCE: chain not engaged when the chainsaw is running and brake is off
NOT FOR THE FAINT OF HEART....with the clutch cover, chain and bar removed, start the saw. with a gloved hand, hold the clutch and squeeze the throttle. if the sprocket engages/turns...its not the clutch.
let me know what you find.
clarkco
SOURCE: ryobi gas chainsaw- chainsaw brake is stuck on. How do I release
You just have to pull the lever back, like it was on the saw, until it clicks/unlocks. It may be hard to do, but thats what has to be done.
SOURCE: How do you put a chain back onto a chainsaw
on one side of the saw are two nuts and a chain tightener screw. loosen the nuts but don't take them off. turn the tightening screw counter clockwise. the bar should slide backwards. the chain goes over the clutch disk and the tangs go into the bar groove. just keep pressing the tangs into the bar all the way to the tip and around the tip sprocket. now turn the adjustment screw clockwise which will tighten the chain. don't tighten it too much! leave a little "play" - tighten down the nuts. plug in the saw and start it. if the saw has a chain oiler press the oiler a few times. as you use the saw the chain will expand and loosen. loosen the nuts and tighten it again just a little.
Testimonial: "Thank you for your very informative help on the chain for the electric chainsaw Susie"
SOURCE: chain fell off
That often creates burrs, this may help with removal, Your OM is excellant for installation, maybe the best I have seen.
http://www.fixya.com/support/r4146814-chainsaw_chain_installation
See pages 19 & 20.
http://www.makita.ca/data/upload/tools/dcs6401%20F-E.pdf
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
There will be a chain brake, grab the brake handle and pull it firmly back to the top handle, this should didd engage the brake, if the chain has de railed the drive lonks will have burs on them which will make it tight in the bar, you need to file all these burs off.
Testimonial: "Spot on. Thanks!"
