It was fine, then it's as if the beans aren't getting into the grinder, the beans I can see do move but don't go down into the grinding part.
SOURCE: Grinder is slipping.
good luck and carefuly.
SOURCE: how can I clean my Gaggia burr coffee grinder?
For parts you can see, use an artists paintbrush. If you want to clean the internals, grind some panko breadcrumbs or raw rice grains, then run some coffee through it a few times before using.
SOURCE: how do you adjust the size of grind with a gaggia
The is a little lever you push up by the bean hopper. Then rotate the bean hopper to change the grind.
SOURCE: how do you change the grind on a gaggia coffee
if it is everything in order you change the grind buy rolling the plastic container of coffee beans(container commands to upper burr holder. If it doesn't go easy than disassemble container and unscrew the upper burr holder, carefully when it comes out, you have some pins and springs from below. do not loose or displace them.
SOURCE: I have a Gaggia burr
Mine broke years ago . I use my finger to move the lever my partner uses the end of a spoon as he has bigger fingers
