The element burned out so I replaced it. The stove and clock still work but the oven and broiler won't. Does this stove have a fuse? If so, where?
SOURCE: How do I troubleshoot oven not heating in a Tappan TEF361ESD?
You can test the element by unplugging the machine, removing the back wall to gain access to the bake element at the bottm, and using a volt meter check it for continuity. There is also a thermal cutoff that you want to check while behind the machine.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
If
your electric oven is taking too long to heat or just not heating up
right, then check out this tip that will give more detail about your
problem.
Oven
Problems Electric Oven is Heating Slowly or Poorly
heatman101
