Run the audio output from the tv rca audio output, to any input of receiver and hook your speakers to receiver. You cannot hook up speakers to tv cause its a low level audio output. Needs to be amplified.
I don't know your exact model of TV so I can't be specific. I do know you need to hook up to audio output not input. Some TV's have audio output and some don't or you might have digital audio output which might not be compatible with your logitech speakers. If nothing else if you have a headphone plug in you might be able to hook up that way.
I have similar situation with my TXDS 565 and could not video out of my unit after hooking up the cables properly in and out of the unit for all auxilary modules... I assume that you have tried to place your vid IN from the cable box to your units vid IN and run a vid OUT cable or S cable to your TV. If this doesn't work for you as it did not for me, then you must run your cable direct to the TV vid IN and run your audio out from the TV audio Out back to your reciever as audio IN in the Video I or II ports on the reciever unit. This will give you audio control through the rec. unit.
I suspect that my is damaged and will not function properly; yours may be too,
My unit is about 10 years old and repair is too expensive so I will run it this way until something else fails and I will replace it... probably not Onkyo.,'
I'd first just hook up the DVD/VCR to the TV and get that working. I'm assuming all you need is the standard cable type connection. This will at least your 4 year old happy. Then you can experiment with the S cable. The S cable will give a cleaner signal from the DVD to the TV. then hook up audio and video cables from the Direct TV to the DVD input. The audio and video will be cleaner using S cables and audio and video cables, but stadard TV cable should get you going. You didn't mention what model DVD player you have. You may have to select the correct inout on the DVD for the Direct TV connection.
Rich
You need 3 pins cable for Components Video hook up and 2 pins for Audio Right-Left conncetion.
There is another option of Yellow-Red-White combination for Video / Audio hook up.
Please let me know what type of set up you need.
If the tv has no audio out then you will have to get the proper splitter and connectors and connect them to the computer or game box and you speakers. assuming the game box has outputs.
You need an Optical Audio Cable. Hook one end to the HD Cable Box and the other to your Surround Sound System. If you dont have an Optical Cable to your Cable Box, then try using the usual audio cables. But, I have HD and it worked with the Optical Audio Cable.
