Horn in my 2006 Ford Explorer has completely stopped working. It does beep when pressing the keyless entry to lock it. We've checked the fuse and it seems that there is nothing wrong with it. Any idea what else could be the problem?
SOURCE: 2002 Ford Taurus keyless entry
if it was factory installed theres usually a fuse in the fuse panel whereever that may be...replace the fuse with the same voltage as the other one says. but if the fuse isn't in the fuse panel its most likely under the hood, to the right...hope this helps. =)
SOURCE: keyless entry won't work
I have a 1999 BMW E46 I have had a problem with the keyless entry myself. I brought the car to BMW Dealer and they told me that my Lock had an issue and that they need to repair some wiring wich would cost me $1,023.98 to find out that it was a fuse that burned out. I have replaced the 5 amp fuse with another one but it burned the fuse again so I put a 10 amp fuse and i have not had a problems since. In my car is fuse # 54 if Im not mistaken. But waht you can do is open the fuse box which is located in your glove compartment look for a diagram that shows you which fuse is where it will give you a fuse name a number where the fuse is located and how many amps fuse it is.
SOURCE: Keyless Entry and Remote
I have had this problem take you drivers door put your key and un-lock from the out side with key (NO) then open the door push un-lock from the inside button and then set from you remote and it should set if not push un-lock then lock and then do the un-lock with the key. Let me know if that works. what my car did was locked from the inside and I had the problem were it would not work till I un-locked from the out side plus I had to go to radio shack and change the battery from the control.
Hope good happens.
Nikki2913
SOURCE: need keyless entry code for a 04 an 99 ford explorer
On your 99 model the module is located behind the left quarter trim panel,mid-way.You maybe able to see it by removing the speaker cover or the cupholder on top. The module will have a sticker with a 5 digit code.
On the 04 the model is behind the right quarter trim panel toward the front about even with the right rear door stricker.
SOURCE: Chevrolet Aveo Keyless entry not working
I recently repaired a similar problem for a friend of mine. I posted the procedure on our website. Here's the link:
http://fixyourboard.com/techzone/automotive/keyfobrepair/keyfobrepair.html
