Exercise & Fitness Logo
D
David Ulloa Posted on Sep 20, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lose speed the treadmill
When start the treadmill the speed in not constante start but loses speed and if increpase the speed word but listen a noise in the engie area
Treadmill Repairs Brisbane
Level 2:
New Friend:
  • Expert 338 Answers
  • Posted on Sep 25, 2014
Expert
Level 2:
New Friend:
Answers
338
Questions
0
Helped
77781
Points
473
Hi david
Have you serviced your treadmill ?
Have you used lube on the treadmill ?
My Trojan Runx treadmill on start up is slow to get to speed and when i climb on while at speed you can hear it losing speed.
There could be a few possible reasons for your Trojan Runx treadmill to have this issue:
  1. Belt tension: The treadmill belt may not be tight enough, causing it to slip and lose speed. You can adjust the belt tension by using an Allen wrench to tighten the bolts at the back of the treadmill.
  2. Motor: The motor may be overheating and shutting off, causing the treadmill to slow down. You can check the motor by opening up the motor cover and looking for any signs of burning or overheating.
  3. Motor brushes: The motor brushes may be worn out and need replacing. This can cause the motor to run slower and eventually shut off.
  4. Power supply: The power supply to the treadmill may be insufficient, causing it to lose speed. Make sure the treadmill is plugged into a dedicated circuit and not sharing power with other appliances.
If you're unsure about how to diagnose or fix any of these issues, it's recommended to contact a qualified technician or the manufacturer for assistance.
tip
How to troubleshoot a noisy treadmill
First verify if your are getting the noise with a user physically on the machine, without anyone on, or both.
Creaking or squeaking while running on the machine usually indicates an issue in your incline motor, deck frame, springs, and or pivot points.
A loud grumbling noise getting louder and louder while elevating speed, usually means you have a bad bearing.
Any knocking noise coming from a treadmill indicates bad bearings in your front roller, rear roller, or drive motor.
Isolate the bearings in the front and rear rollers from the drive motor bearings.
To test: Unplug the machine, remove the main shroud, remove drive belt from drive motor and front roller pulley.
After doing so, move the treadmill belt by itself by pushing it backward or forward with just your hands and listen for any noise, if you get any noise it is most likely coming from either the front or rear roller. To isolate the noise from the two rollers you can loosen the belt and turn each roller individually.
If no noise with the first test, go ahead and start the machine and run it at a low speed. You want to listen for noise, if you get knocking or grumbling while drive motor is running with no drive belt attached then the issue is in your drive motor.
A lot of times simple maintenance will save your treadmill from noise, you want to make sure and lubricate your treadmills pivot points. Incline motor bolt, shaft, deck screws, and or any pivot points on the bottom of your machine. Metal on metal pivot points are usually the culprit in most cases.
Pivot points are just areas of high friction where there may be a bolt, washer, and nut attached to the base of your frame or any hinges on your folding type treadmills. Metal on metal needs to be lubricated to minimize wear and tear of those areas.
Synthetic grease works best or any spray on lubrication works fine if you do not want to remove any bolts or hardware.
If you ever find yourself needing technical support, please do not hesitate to call us 888-713-2880 or visit us online at www.sportsmith.net
on Jul 13, 2015 • Exercise & Fitness
Making very loud whistle noise
Be sure to verify if you are getting the noise while you are physically on the machine or with no one on it
To test: Unplug machine, remove the main shroud, remove drive belt from drive motor and front roller pulley
After doing so, move the treadmill belt by itself by pushing it backward or forward with just your hands and listen for any noise, if you get any noise it is most likely coming from either the front or rear roller. To isolate the noise out of the two rollers you must remove the rollers and turn each one individually.
If no noise with the first test, go ahead and start the machine and run it at a low speed. You want to listen for noise, if you get knocking or grumbling while drive motor is running with no drive belt attached then the issue is in your Drive Motor.
A lot of times simple maintenance will save your treadmill from noise, you want to make sure and lubricate your treadmills *pivot points. Incline motor bolt, shaft, deck screws, and or any *pivot points on the bottom of your machine. Metal on metal *pivot points are usually the culprit in most cases.
*Pivot points are just areas of high friction where there may be a bolt, washer, and nut attached to the base of your frame or any hinges on your folding type treadmills. Metal to metal needs to be lubricated to minimize wear and tear of those areas.
If you have any other questions please do not hesitate to call us or visit us online
888-713-2880 or
http://www.sportsmith.net/supportsearch.aspx
3answers
Treadmill willnot run
Check motor....if motor ok check the controller
Motor making loud buzzing noise
The grinding noise could be asking for lube. If that is possible, do it.
1helpful
2answers
Rattling noise when starting and idling
It could be lose ehuset system parts or catalic conveter problem but itsan 86 thats 25 years old but i have an 85 ford ranger and it still runs great look for things that are lose or moveing around exhust system
My 15.5 image treadmill lights up but will not start.
I have an Image treadmill model #: IMTL31504.0. It will come on for 1 second and then it appears to lose power. Any thoughts? The belt does run for that 1 second.
Noisy treadmill.
lose some weight -lol-its working for mine,cheers!-mine is noisy too-place a square of shaggy carpet under her- i find mine slips somewhat too even tightened-ok ill lose some more!
Top Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
