Tablet was used until battery was dead and placed on charge, however it wouldn`t charge, so I purchased several new chargers, but it still won`t charge. The last charger purchase was a nexus orginal one
If the USB port is becoming worn and no longer works, you can purchase the USB port and solder it on the board to replace it or replace the whole board, which is more costly and prevents you from needing to solder anything.
just google it many wideos on it.
This, unfortunately, is a common problem among Nexus users. It appears the USB port becomes problematic and prevents the phone from charging. Rather than tinker around with replacing the port, there is a simpler solution. Try purchasing a wireless charger as suggested in this article: Cure for the Non Charging Nexus 7
SOURCE: Charger port not working
I wouldn't mess with trying to fix it. There is probably a loose wire and short of soldering it there is little you can. Call the manufacture and have them warranty it for you. It is covered for one year: https://support.google.com/googleplay/answer/2662734?hl=en
