Hi there you can empty the waste toner box wich is located inside drum unit.
The procedure is next:
open front cover and leftsideway door release the blue handle above the drum unit pull out the drum unit on top of drum unit, near handle is located plastic grey colored cork remove it and by means of vacume cleaner clean the vaste toner.
Note that if you flip out the drum unit and try to empty waste toner it could be messy and the toner can get into charge roller or on drum cleaning blade and then you need to change it completly.
this is a canon generic error code that points that the fixing/fusing heaters or sensor has a problem try to swtch off & on the unit, check the ac power supply maybe its not stable, if the problem persist.you have to call your service provider regarding this.
check available drivers in your computer,select the cannon model you have or any other compatible cannon model.if no success download from the internet,www.digipro.co.uk/products/photocopier-software/a3-copier-black-white-drivers/
