Just comes up after 8seconds with E1. Please help
Hi, Go to my website . I can fix for you. I used to work for Cardiotech .
Home Treadmill Repairs Brisbane Brisbane Leading Treadmill and Fitness...
SOURCE: I have a pro seirra treadmill that keeps stopping
Your problem might be a magnet has fallen off inside. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
SOURCE: Tuturi J661F stopped working - Error E1
Your problem might be that a magnet has fallen off. Here's an illustrated tutorial that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
SOURCE: Hi my treadmill starts and
Motor does not operate; Display CPU cannot read the optic sensor signal.
Check it and adjut the Reed swicht and optical Sensor
SOURCE: york tv evolution treadmill e1 problem
INDICATE ABRUPT SHUTDOWN of the belt as the motor control detect a sharp increase drive current,and inmediately stop driving the belt. Watch this videos tips:
http://www.youtube.com/watch?v=qgb2TY3WCkg&feature=related
http://www.youtube.com/watch?v=-oeXTKqWECw&feature=related
http://www.youtube.com/watch?v=GPI6dFJCUA4
http://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitness
http://www.fixya.com/support/r10786838-test_procedure_dc_motor
SOURCE: i have a jkexer polar 5090 treadmill and its coming up E1 any ideas please
1) You must adjut the speed sensor, clean it, tight the connector very well.
see the diagram attached.
2) Lube the deck belk, you have deck belt worn.
3) Lube the rollers bearings.
4) Test the input voltage for motor, if there are the motor need repair.
5) Test the output board, for input voltage motor, if there are not the board is faulty.
Sincerely. God bless you,
