The top rack does not pull out all the way. It appears to have a stopper placed in the wrong location. Can it be changed?
SOURCE: GE triton dishwasher middle spin arm not spinning
I had the same problem and found two things which were causing it
-The O-ring was missing off of the tube connection on the back of the dryer that inserts into the sprayer tube. I found a size 11 O-Ring at Home Depot and it worked
-The openings on the underside of the spray arm are what propels the sprayer to spin. I found small pieces of plastic debris in the openings and cleaned them out.
Now the middle arm spins like it should.
SOURCE: GE Triton not working
Jitterbugclu-
I may have the solution. Husband just turned off power to dishwasher via circuit breaker. Waited around 30 minutes.
Restored power and Triton came back with normal lights.
I just ran a cycle and all was well. Hope this helps you.
My fingers are crossed because I don't know what happened but did read on another site that this should be the first thing you try before expen$ive repairman.
Reply back if it works!
TootieC
SOURCE: ge triton xl dishwasher
The part you need is a WD13X10008 from GE Parts 800-626-2002 or order online at GE Consumer Service web site here
SOURCE: GE Triton XL Dishwasher not cleaning glasses
Check to see if the spinner holes are clogged with food..or
debris...this is what makes the sprayer arms move....water
pressure...which is pumped up through the sprayer arms .......I s the
pump working...if so....then you may also have some blockage at the
base of the pump where the screen is that keeps impurities out of the
pump....check to see that food or debris is not obstructing this.
I hope this help....have a good day and good luck...please rate my effort...the Fang
SOURCE: GE dsd 6700 top rack glider wheels not turning,
remove the tray and look at the wheels to be sure they are completely attached to the tray itself. If they are spray them with PAM or another cooking spray product to lubricate them.
