LDS5811BB LG dishwasher IE code. What does this mean? Water not filling dishwasher.
SOURCE: LG LDS5811BB power cord is
Try first to plug the dishwasher on a different power outlet just to check that this is not a problem with the power outlet where its plug in if still no power this can be a problem with the power cord or the power supply unit of this dishwasher and needs a replacement...
Hope that helps.........
SOURCE: ''IE'' error code on my LG dishwahser
According to the owner's manual it's a 'water input error'. You have to check for a kink or clog to the water hose running to your machine.
SOURCE: door hinge adjustment to LG Dishwasher
There is no adjustment to the door hinges. If your hinges are failing they will need to be replaced.
SOURCE: LG dishwasher won't dry
Recommend you confirm that the rinse aid is not empty.
If problem persists and you are not getting an error message, contact LG service and pres them for the retrofit they released for the LDS5811 (and other models) that dramaticly enhances the drying ability. Until it is replaced, be careful because it is possible tht water will leak from the door panel (not directly from inside the diswasher, but through the door panel-based drying system.
Press them for a no charge repair for this problem and be persistant, firm but polite. If the agent is not helpful on their own, request to be "escalated" to his/her manager. Good Luck! and report back what you find. Thanks!
SOURCE: LG Dishwasher LDS5811bb. Water is leaking out
The dishwasher may not be levle side to side and front to back.
Se the installation instructions or go www.lgusa.com
they may have the instructions on line.
This will cause leakage at the door.
If the leak is @ the bottom left it may be from the drying vent assembly.
The vent would need to be replaced with an updated vent assy.
Hi
Error
code IE on LG dishwasher means Inlet error. This error comes up when the Water
Supply Tap is closed or Water Supply is shut off. If water supply is turned on
then make sure that the Inlet Hose is not kinked and water Pressure is not low
(should be above 10 psi). Next thing to check for is Water Inlet Valve, measure
the electric resistance of Inlet Valve. (950-1300 ohms) Make sure the filter of
Inlet Valve is not clogged.
Hope this helps... Please post back
for further assistance.
Daniel
