C900, purchased in May 2011.
SOURCE: Nordictrack motor will not run when start button is pushed.
Likely the cover of one of the motor brushes popped off. Unplug the machine before you pop it back in place, then try it again.
If that doesn't work, most likely it's the motor control board, or possibly the console, or finally just a loose connection behind the console.
But most likely, it's the motor brush cover. I've been seeing that alot with this model.
SOURCE: I NEED THE NORDICTRACK 9600 INCLINE TRAINER TREADMILL SCHEMATIC
contact me @ [email protected] I will send this to you.
SOURCE: I just purchase a NordicTrack
check that all screws nuts etc.are tight,,also you could try some silicon spray under the mat,,it is a type of oil,,the directions should of told you to oil under mat and run for awhile before you use your treadmill,,,ps dont use any type of oil..i have used water dispersant oil before and it was ok,,but get the proper oil as soon as you can,,,hope this helps,,cheers.
SOURCE: NordicTrack Elite XT Treadmill-display problem
1) Run the calibration software for easy diagnostic and fix it. go to owner manual, and go under the hood for following the steps.2) Exchange the batteries by new ones, cleanup contact from the batteries for oxide, and see if there are Not SOME WIRES BROKEN OR LOOSE.3) Tight the keypanel from flexible cable vs display board, 4) tigh the display board vs lower board. 5) attached the sensor reed switch by 1/8" or 3 mms adjusted according. 6) Test the main motor controller board for 115 Vca, and then +5 vdc for output coming to display board very important.
7) Test the transformer for primaRY VOLTATE see the tip adjust how to do it. 8) Finally see the block diagram that I did like like you for easy diagnostic and fix it.to.
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitness
sincerely. Happy new Year. G-d bless you
ernesto cuadra
managua, nicaragua
