Phone rings and goes to voicemail too quick
SOURCE: no ring,goes directly to voicemail
your phone is on 'do not disturb mode'. call your provider and ask how to shut it off. for telus mobility it is *79 then hit send
SOURCE: phone rings once, then goes to voicemail
Yes, turn off call forwarding or set up longer delay. at least 15 sec.
SOURCE: HTC Touch Pro only rings twice before switching to voicemail
I think the issue is a misconception on the operation of the phone. The phone flashes for the first ring, vibrates for the second ring, and then rings for the 3rd and 4th ring before dropping to voicemail. it requires a registry modification as can be found on some forums to make it "ring immediately." If you put the phone on vibrate it will buzz immediately and skip the flashing lights step.
SOURCE: nokia 6210 voicemail only rings 5 times before
go to your tone setting and then you wil see it says sumthing about ringing once, assending ect, change that to assending!
SOURCE: Incoming calls ring 3 times
Your voicemail thinks that it is ringing six times. The time that it takes to transfer to the extensions counts. Whiloe it seems that there is a lapse the system actually is using enough time to ring six times total. If you need longer ring time at the extension, take in account the transfer time and set it to pick up after 8 or 9 rings. It will actually only ring six. You just have to trick the system a little.
