Electric washing machine. Electrical out but I checked the fuses and everything was okay. Also, the dryer stacked on top works fine.
Hello friend, thank you for your post!
I understand that your Frigidaire washer is not coming on and you are looking for a restart button. The best way to reset your machine is to disconnect power from it for ten minutes and you can do that by unplugging it or flipping the household circuit breaker off. If that does not correct the issue it could be a problem within your control panel and I would recommend having a professional come out to properly diagnose your appliance to avoid any unnecessary part purchases. Hope this helps. -Matt
To Stranded,
Here is a link that will put you directly to free support and a manual to guide through the trouble shooting function. sparke needs help with Frigidaire Washer on ManualsOnline com . If you are familiar with a meter to troubleshoot and identify voltages. Start there. If the display is functional. Here is another forum you can tap for resources to compare. Basics first. How to enter diagnostic mode on Frigidaire ATF7000 washer Appliance... .
And you will need to take it apart.. here is the link for that solution.
Frigidaire Affinity Washer Disassembly
Say how you made out and if this approach helped please?
Fare. Well.
SOURCE: frigidaire affinity indicates 'err' light - nothing else
Dear Abhkss
ngfam at you service,
Sounds like you need service for electronic parts!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
SOURCE: Frigidaire Affinity Atf7000e...Does not load up water.
clean your inlet screen...onthejob...take hose off and take screens out of inlet water vavle and clean then replace..onthejob
SOURCE: Error messege, front loader wont start.
my name is joyce
first try the simple step, unplug unit for 60 secounds, then replug unit back up. reset load and see if that works. let me know if I can be of further assistance.
joyce
SOURCE: burning smell during spin cycle on frigidaire washing machine
Open lid as you would load clothes and hold the inner drum with all the holes in it. Give it a manual turn left, then right. If it spins in both ways the main bearing is gone. This is not a DIY because the new bearing has to be pressed on at a machine shop, or an appliance repair shop.
