I tried to put videos on my flash drive it just says unsupported files
Chek if formating is in fat filesystem, fat 32 has a size limit for single files of 4 GB fat 16 limits it to 2 GB so if you are trying to put a dvd-rip of 4.5 GB there is your problem, anyways right click on the drive in my computer, click-properties, under general you will see what file system it is, to change you will need to format the drive, and be careful because formating deletes everything off targeted drive - to format right click on the drive and select format..., choose ntfs file system and quick format if you want (speeds up the process), (be sure you saved data on hdd beforehand) and hit format. if the issue is not file system related i rly don't know what else could it be
