When I first open my Samsung galaxy tab 10.1 wifi- tablet the screen responds very slow or you have to push many times for it to make it to the selected page ?
Your phone hangs, you can use some apps to speed up your phone, this maybe help, I always use LEO Privacy to boost my phone.
LEO Privacy Applock Hide Safe Android Apps on Google Play
You might have too many apps or you might have too many apps that are active in the background that are slowing your tablet down. Uninstall unused apps or turn them off through settings. Apps always sync in the background, even when you don't use them. When too many apps are running at the same time, they drag down the wifi speed. Go to Settings>Wireless and Networks> Data Usage, view all the apps that are actively syncing. Also, in Settings>Device>Battery, you'll see which apps are actively draining your battery (if this is also an issue). You might be surprised which apps are either draining your battery or always syncing.
SOURCE: i need to download user manual for samsung galaxy
You can download the available documents from the following website.
http://www.samsung.com/uk/support/search/supportSearchModelResult.do?menu=SP01&searchWord=galaxytabpc&default_searchInputBox_value=Enter+model+number+or+keywords&searchInputBox=galaxy+tab+pc+
Please let me know if you require any further assistance.
Thanks
SOURCE: can I use my galaxy
Go to settings -> wireless and network -> mobile AP -> press the mobile AP check mark -> click yes. the access point name and password is located on the bottom of the page in the mobile AP menu. cheers.
SOURCE: samsung galaxy tab . written manual I would like
http://www.samsung.com/us/support/downloads/SCH-I800BKAVZW if this helps please vote
SOURCE: My samsung Galaxy Tab GT
Somehow this is related to the SD card. I had replaced the original 2 GB SD card with 8 GB one and it was working fine. I used to use the flash as a torch by using the record function with flash and then pause which leaves the flash ON to be used as torchlight. But then it broke down displaying Camera failed. I did lots of troubleshooting but it didnt work, finally I inserted the original SD card back and the cam started working. Try this:Switch Cam Storage to SD card then remove the SD card from the cell and reboot the cell without the card. let the cell work for few mins(30 to 60mins)without the SD card. Now insert the SD card and reboot the cell. wait for few mins and check. Replacing the SD card from another cell may also work.Good luck
