If all the indicator lights are flashing after you've initialized your machine, reset it by turning it off and then on. If there's no disk in the brewing mechanism, all the indicator lights will flash.Sep 5, 2020
Explanation of lights
When the appliance is turned on Flashing lights: the appliance is heating up to make coffee Lights on steadily: the appliance is ready to make coffee The lights flash rapidly: the tank is empty or the appliance will not make coffee. See the section "2. Filling the water tank" 3. https://www.delonghi.com/Global/countries/se/Manualer/0132106141.pdf
This is telling you that it is time to clean the coffee maker. Press the minute and hour buttons at the same time and hold untl the light stops flashing. Take out the water filter and fill the water tank to 10 cups and add 2 cups of white vinegar. Put the water tank back in, without the water filter. Take out the permenant coffee filter. Turn it on and leave it until about half the water goes through. Turn it off. Let it sit for about an hour, then finish the job. Then, run 2 pots of clean water through. You are good. It will notify you to clean your system every 40 pots or so.
If your brewer is only flashing only after it heats up, your temperature might be set too high. Try turning it down, and if this doesn't cure it, your limit thermostat might be blown.
The manual states that after you descale, you have to hold down the hot water button for 6 seconds, that will turn it off and "reset the timer" till the next time it needs to descale.
