Water fills in then it starts washing but before tablet is released fast and delicate lights start flashing ,machine continues until it drains and then stops.
A10 4 + 6 Heating circuit Heating element, connections, module,
relay, pressure switch
A10 Open circuit in heating circuit.
• Check the circuit of the heating element (26 ohms).
• Check for an open circuit heater cut-out.
• Check pressure switch open circuit (connections 11-14).
• Check wiring and connections between module card, pressure switch and heater.
• If all above is OK, replace module card.
SOURCE: HOTPOINT DISHWASHER FDW60
I have just had my dishwasher fixed by Hotpoint, as the heater was working and the dishwasher only stopped with the fast and delicate lights just before the drying process he replaced the main control board. This has solved the problem, I suspected the fault to be the thermistor as the heater seemed to be getting to hot but I had no idea where it was.
It turns out the thermistor is attached to the main control board and hangs down behind the front door that gives just a rough temperature level for the main control board.
As it's soldered directly onto the control board I would suggest replacing the whole control pcb for anyone with this fault unless you can find any spec details for the thermistor.
SOURCE: Error lights.
This is a Circuit Board that is bad (main control).Do not repair this because the problem returns,and returns.
SOURCE: FDW60 Fast and Delicate Lights Flash
This is a bad control board that if replaced will only repeat in a short time .My advice is to contact the manufacturer and complain,you have the right as a consumer to do so.
SOURCE: fast and delicate flashing
Your control panel is bad.My advice is use your warranty if you have it .If you don't ,toss this machine out,there should have been a re-call on this .You are one of many many that are having to deal with a problem that the manufacturer should be liable for. Dont't let GE (hotpoint) go not knowing that your D/W is broken ,look for a class action law suit to be in the making,which is not enough to correct the problems at hand .I don't advise repairing this unless there is a modified part to replace the defective one. Again I'm with you on this ,and sorry for all the consumers that are ripped off by manufacturers (in my eyes) . Please rate this !
