Lg 3510 soundbar
SOURCE: can i get the driver s/w for LG GD 3510
Go to LG mobile website in internet & get the required driver software,. Else update your software to latest version which may also rectify the problem in your cell phone.
I am going to guess here that you are running this through an audio system or a cable box. Your audio needs to come form the source, not the TV. Ex. If you were to go optic cable out of your cable box and into the TV optic then you would get sound out of your TV speakers. Go direct to sound bar.
Testimonial: "It's a Polaroid tv we ran the optical cable out of the soundbar into the headphone connection behind the tv with a jack on the end of the optical cable but no sound or working! No cable or sky as not using that using built in free view in tv"
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window " to get gathered related posts.
