Riccar 8955 Upright Vacuum Logo
A
Anonymous Posted on Sep 18, 2014
Where is the reset botton on riccar
How to resey
Thatvacguy.com
Level 3:
  • Riccar Master 1,619 Answers
  • Posted on Sep 19, 2014
Thatvacguy.com
Riccar Master
Level 3:
Answers
1619
Questions
0
Helped
605038
Points
3345
The reset button is on the lower back of the vacuum
Our handheld Riccar Gem R-4 stopped working. I looked and the bag was super clogged... oops. I cleaned it up but the machine won't turn on. Is there a fuse or breaker or ... is the motor shot?
Riccar uses an external thermal reset which is more reliable than most brands which use a thermal reset built into the motor. On your Riccar it will be on the back on the bottom left. It is a little tiny button that you will hear "click" when you push on it if it has been popped. If not it will not push in and you won't hear the click. The older models did not all have a reset button. If you have to keep pushing the reset it means that most likely you have a clog somewhere or the bag is full. It's rare but occasionally a thermal reset button may go bad and need replaced.
https://www.google.com/search?q=Riccar+Gem+R-4+thermal+fuse
Where is the reset button on riccar supraquick
Link below to company with some info and contact info
https://www.riccar.com/customer-support
One place it says if your vacuum has a thermal overload reset see owners manual if vacuum will not start. It also says make sure hose is not plugged and filter and bag are good.
Manual below has a troubleshooting guide
http://media.riccar.com/manuals/RSQ1_OM1706.pdf
https://az589519.vo.msecnd.net/productdocuments/Riccar_RSQ1_supraquick.pdf
1helpful
Riccar 8650 vacuums reset.....cannot find as stated just above left wheel and to the right....all smooth dark blue plastic housing
Your 8650 is likely about 30 years old. It may not have a reset switch. If it won't run it may need a new cord or switch. If it's in good shape it may be worth having it looked at by your local Riccar dealer.
Riccar r30d I have checked the hose and tried the reset. The bag was just put on and I took it off and put on again. When I plug it in now the lights turn on but nothing at all happens.
When you press the reset button you must make sure to push it in far enough. You may need to use a small tool to make sure you are getting it reset. Your Riccar vacuum is still under warranty. If it is not the reset button I suggest you take it back to your dealer for repair.
Why does the riccar vacuum reset button not depress?
In my experience the Riccar requires reset when it has ingested something that jams the roller such as the fringe of an Oriental carpet. Be sure to clear any such obstruction, then I use a ball point pen to press the button. It does not move very far to accomplish a reset.
I have a Riccar 8750, when I plug it in any outlet and turn on the headlight does not come on and the vacuum does not turn on. The reset button does not seem to help. It worked fine when I shut it off last...
An 8750 is likely at least 20 years old but still may have lots of life left. I still have 8600 series Riccar vacuums brought in to my vacuum shop for service. You may have a loose wire, bad switch or power cord. I would take it to my local Riccar dealer to diagnose and repair.
6helpful
Where is the reset button on the Riccar 8995
The reset button on the Riccar 8955 is located on the back of the vacuum cleaner, at the very bottom, right above the rear wheels. You can push the reset button with a ball point pen or something similar.
9helpful
Where is the reset button located?
Greetings from GoVacuum,
The reset buttons on the Riccar vacuum cleaners are located at the bottom of the vacuum cleaner in the back, underneath of where the wand sits on the vacuum cleaner.
Here's a picture of a Riccar 8925 which replaced your 8850 a few years ago, but the reset switch will be in the same exact location on all Riccar uprights;
Here's a closer look of the reset switch;
I hope that I was able to answer your question. You can avoid the reset switch flipping in the first place by always ensuring that you change the bags frequently and when full, as well as the motor filter that sits underneath of the bag. Also keeping the vacuum from clogging will prevent this.
If you found this repair solution helpful to you, may you please click the 4 Thumbs Up Icons in the top right hand corner to help me out here on Fixya? I really do appreciate it, thank you so much.
Chris
GoVacuum
2helpful
2answers
Riccar 8955 sweeper won't run...where is thermal protection switc
thermal reset is located on the back of the machine at the bottom
3helpful
Riccar 1500p vacuum won't start
it has a thermal fuse that shuts it down if it over heats. Check the hose , wands and floor tool for blockage and check your bag and filters as well.
Oct 01, 2008 • Vacuums
Top Riccar Vacuums Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
