Computers & Internet Logo
A
Anonymous Posted on Sep 18, 2014
How to open the DVD case? - Extensa Acer Computers & Internet
Gregory Pettiford
Level 1:
Problem Solver:
  • Contributor 20 Answers
  • Posted on Sep 22, 2014
Gregory Pettiford
Contributor
Level 1:
Problem Solver:
Answers
20
Questions
Helped
3102
Points
33
In front of your dvd is a little pin hole place a diaper pin in it and push the case should open .On your computer you can also go to My Computer look under dvd right click on the icon ,when the drop down menu show click eject.
How to get DVD out of machine
You will need to open up both dvd case and dvd player! the rubber type band that turns the wheels to open tray is bad, not tight enough to turn wheels! This rubber type band is located at the front of tray. you might be able to get tray to open by taping the top front of player after you push eject, just not hard enough to bend case.
How do I get the DVD out of the DVD player
Why not open cd&dvd?
By opening what do you mean? Is it Tray or File? If Tray is not opening, Turn your Computer off, then insert a needle or a pin in the hole just beneath Tray and push the needle in slowly, after a few attempts, your Tray will open. But don't force, if you don't find yourself comfortable doing so, better call authorized service professional.
If it's about not opening Folder or File, there may be several reasons like dirty surface of CD/DVD, Corrupt File(s), Improperly created Sessions on CD/DVD etc etc. If this is the case, you may first try to clear the Surface of your CD or DVD with a soft cloth, slowly. If files or folders are not proper on your CD or DVD, or if you have incomplete writing sessions on your CD or DVD, you can not do anything to open them. Just create another CD or DVD. But if your CD or DVD is rewrite capable, you can format your CD or DVD and rewrite the data, but in this case your Data that's on your CD or DVD will vanish away.
If these things are tough,l please contact Authorized Service Center or your Computer Dealer.
1helpful
How to open the disk drive
Open the Computer folder in Start Menu, select the DVD Rom Icon, right click, select Eject. If a DVD or CD has exploded inside remove DVD Rom and open the DVD case. Sometimes if you open the front case door cover and access the DVD/CD drive door you will see a tiny hole to insert a open paper clip that will open the tray.
How to open dvd to get disk out
Open Computer in start menu, right click on the DVD/CD rom, Eject. If that fails,Turn off the machine, use a thin instrument to manually pry open the tray. OR remove the DVD/CD rom and disassemble the case. If the DVD or CD has exploded.
1helpful
Tsunami 710-lk/premium computer case how to remove front dvd/cd & floppy drive bay case panels
To remove the DVD/CD in your computer case. First turn off your computer. Remove the power cord, open the left side of your computer case. Then remove the connectors of your DVD/CR ROM then unscrew all the screws that screwed in your DVD/CD ROM. After you loosen your DVD/CR ROM push it out and pull it out in your casing. Hope this procedures will help you.
A dvd is stuck in the dvd player
something stuck our dvd-door.
1. open the dvd
2. remove the thing that block our dvd door (like paper, tissue, paperclip)
or
maybe our dvd mechanic door had block by dust
-----basicaly, clean it.
in my case. I knock the upper top of the dvd door hard (but not by hammer, by my hand) while i push open button (the menu open/'open' word is display at the menu). if u're lucky, the dvd door will open
1helpful
2answers
Will not open
The motor that open the door has probably died. This is a common occurrence with cheaper DVD players. You will probably have to buy a new one.
If there is a disc stuck in there, you will have to remove the screws underneath and open the case to remove the disc.
DVD drive/Opening Case
In the front cover of the DVD there is a very small hole. straighten out a paper clip and gently insert into hole. the Door will manually open.
The case slides off the frame. It may need a little more pressure to over come the clip pressure.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
