After cleaning ice bucket, I cannot snap it back into place
SOURCE: ice maker leaks inside freezer
check the water discharge hose which fills the ice maker after ice is dumped into the bin. the line is located in most cases at one end of the ice maker and allows the water to flow into a funnel like device above the ice maker mold. the hose has the diameter of a penny, it is probably misaligned with the ice maker itself/
SOURCE: Samsung french door ice maker
Check my solution here. The noisy sound is the swing arm trying to knock out some stuck ice.
http://www.fixya.com/support/t1141317-two_issues
SOURCE: samsung ice maker rotor broken
Should not be a problem just enter model number in search feature and click on Ice Bin. If you need any help with this let me know, Sea Breeze
SITE=> http://servicepartstec.blogspot.com/
SOURCE: Samsung RS2555SL Ice Maker gone nutty!
The icemaker relies on the motor to twist the ice tray about 120 degrees or so the dump the ice out of the tray. In order to get the ice to separate from the tray the force of the motor actually torques the tray against the rear plastic support (much like you would twist an old fashioned ice tray that you fill up by hand). Anyway, this puts a lot of force on the plastic elements that support the tray and they break after time. Once the plastic support breaks in the back there is nothing to get the ice out of the tray and each subsequent filling of the ice tray results in water spilling all over the ice bin and eventually leaking out the front of the refrigerator. You can order the part and fix it yourself (the part is DA61-00244A and is available from a number of websites. Total cost about $16 with shipping.
SOURCE: ice maker wont work
If the ice maker has completely stopped producing ice.
Check to see whether the ice maker has been turned
off. Here's how to check. Look for a wire along the right side of the
ice maker that looks a bit like a coat hanger. If this wire is in the
raised position, the ice maker is turned off. On some units you simply
lower the wire to the down position to turn the ice maker on. On others,
you lower a small red plastic lever to lower the wire. If the wire is
in the proper position check the freezer temperature, it should be
between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the
ice maker may not produce any ice. Check your door seals and thermostat,
repair/replace as necessary.
If the ice maker is producing ice poorly.
When an ice maker is producing ice poorly--when it
produces just a few cubes or none, or when the cubes are too
small--it's usually because of a clogged water line or a defective water
inlet valve.
First, check the water line attached to the back
of the refrigerator for good water flow. To do that, first turn off the
water supply valve. Then remove the water line from the back of the
refrigerator. Next, place the water line into a bucket and momentarily
turn the water valve back on to test the flow. If the flow is poor, you
need to repair, clean, or replace the tubing or the shut-off valve that
supplies the water. If the flow is good, you may have to replace the
water inlet valve.
