I have replaced control board
Since I don't know what does work I am kind of shooting in the dark.
Does the ac heater get hot ?
The spark ignitor is part of the control board. But won't work?
I assume that you have a user manual but I am including a link to download one.
https://www.dometic.com/f6e8a773-69f5-4624-9b35-54e8801da7af.fodoc
Note that there are three fuses. B (12V control) and C (120V Heater) on the control board and a thermofuse L located on the stack.
If L is good and everything else is good there should be 12VDC on J1 and at Fuse B
Testimonial: "I have now pulled the entire unit out the RV. While I was taking it out I heard a gargling noise from the coils, is that okay? I will be looking at it more in the morning. I do have it powered up, still no clod."
Gurgling is normal. The coils are filled with liquid ammonia. All it takes to make it cool is to heat the area that the burner and the 120v heater heats. Did you confirm that the 12v is connected?
Watch this video.
SOURCE: AC,DC, gas RV fridge Dometic
You more than likely need to replace the control cable between the upper and lower board. It comes as a kit with the upper board. You can also do a bypass test by unplugging your thermoster from the circuit board. The thermoster is the temperature control for the refrigerator nothing to do with the freezer.
[email protected]
www.coachtech.info
734 777 6432
SOURCE: Dometic rm 2612. Shuts down on gas.
Ron;
Check the burner assembly. 1 screw, remove the sheet metal cover and clean it. The burner collects rust. This is the likely. Other issues would be the gas pressure usually checked with a manometer. Should 11" of water column. If your furnace works good then the gas pressure is probably ok. Also could have a faulty ignitor which sends a miliamp signal back to the circuit board. Check the burner first, after that leave the cover off and turn the fridge on. Watch the ingnitor attempt to lite the burner. Be sure the spark is going to the burner and not shorting out on the sheet metal it is mounted in. If it is shorting to the frame the ignitor needs replacing.
Thanks for using Fixya
Jerry
SOURCE: Freezer working, fridge isn't.
It is possible that your cooling unit is failing due to a blockage. The solution used to cool starts at the top of the fridge and works its way to the bottom. If there is a blockage in the cooling unit it could produce the symptom you have explained.
SOURCE: Camper fridge dont cool
I also had the same Model Make. I removed my fridge and placed it upside down, occasionally shaking fridge within a 24 hr period. This seemed to re-mix the ammonia solution and the fridge is working.
This may work for you but look for yellow stains if you see any your fridge is leaking and would require repair.
SOURCE: I have a Dometic RV fridge that wont get cold. it
It sounds like your cooling unit is going out. Here's a couple of things to check. Do you smell any ammonia when you open either one of the doors? When you look at the rear of the fridge, do you see anything that looks like rusty water that has run down any of the metal tubes and dried up? If the answer to either one of these is "yes", then youll need to start looking for a new fridge or replace the cooling unit on the one that you have.
