Screws for Mounting TV to Wall Bracket:
The most common screw for securing the TV to the wall bracket is an M8 screw. The other screw sizes for some TVs are M4, M5, and M6. The length will be determined by the type of TV you have.
https://removeandreplace.com/2016/10/18/tv-wall-mounting-what-type-of-screws-do-i-need-from-wall-bracket-to-tv/
VESA Specifications
VESA STANDARD
HOLE PATTERN
SCREW SIZE
MONITOR WEIGHT
SCREEN SIZE
FDMI MIS-B
50 x 20 mm
M4 x 6 mm
? 4.4 lbs / ? 2 kg
4" to 7.9"
FDMI MIS-C
75 x 35 mm
M4 x 8 mm
? 10 lbs / ? 4.5 kg
8" to 11.9"
FDMI MIS-D
75 x 75 or 100 x 100 mm
M4 x 10 mm
? 30.8 lbs / ? 14 kg
12" to 23.9"
FDMI MIS-E
200 x 100 mm
M4 x 10 mm
? 50 lbs / ? 23.7 kg
24" to 30.9"
FDMI MIS-F
200 mm increments
M6 x 8 mm or 10 mm;
M8 x 15 mm
? 250 lbs / ? 113.6 kg
Yes, you just have to remove the stand first, the screws will be Metric M5 or M6 that you can get from HD or LOWES, the length will be depended on how thick the bracket is.
When you buy mounting bracket kits, it should come with a bag of screws for attaching the TV to the bracket.
If you are talking about the mounting screws that go into the back of the television to mount a VESA sized wall bracket, then it's most likely 5mm screws. The length of the screws could differ, depending on the bracket you are attaching, but usually 12mm or 16mm can be used. just make sure that the screws are long enough to thread into the TV completely, but not too long, or they may damage internal components.
If you are talking about the Lag screws needed to mount the bracket to the wall, then use 3/8" width lag screws 2 1/2" to 3 1/2" long, depending on how deep you have to go before hitting the wood stud.
Metric M5 or M6, when you buy wall mounting bracket, it will came with a bag of screws for attaching the TV to the bracket. All my wall mounting brackets for my TV come with screw.
