Dell Venue 7 or 8 Tablet in Black Logo
D
Dennis Bieu Posted on Sep 18, 2014
How do I turn off the touch tone on the key pad?
When I respond to mail, the key pad has a touch tone. I want to turn the touch tone off
Muhammad Talha
Level 1:
New Friend:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Aug 21, 2015
Muhammad Talha
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
7
Questions
0
Helped
1148
Points
14
Go to settings.
Language and input.
Keyboard and input methods.
If google keyboard is your default, tap on the settings image.
Under General, there is an option called "Sound on keypress".
If checked, un check it and the sound will disappear.....
Tablet is not responding ,to any comands
Touch Screen Not Working Android Problem [Fix] - TechKhoji
www.techkhoji.com > Android
Feb 27, 2014 - How can I reboot my tablet, the touchscreen is not working. ....Sometimes when I turn on the screen it doesn't respond to my fingers. Then I ...
Android Tablet Touch Screen Problem Solution - YouTube
? 21:36
https://www.youtube.com/watch?v=h7_aqvkfKL4
Jun 16, 2014 - Uploaded by SOLOMON BOTCHWAY
I CANT Believe it, i Actually fixed my tablet.. all i did disconnect the ... my touch is working how to fix the screen not showing? ....2 WAYS TO FIX IPAD TOUCHSCREEN NOT RESPONDING - WORKING - Duration: 5:17.
Samsung galaxy Tab S 10.5 not responding by touch ...
? 2:54
https://www.youtube.com/watch?v=XkK9zCx46gs
Jul 7, 2014 - Uploaded by Linkhunter
i just the new tablet by samsung i recharge the tablet after that isnot responding by touch and so Sim card do ...
Touch Screen Not Responding ' DaniWeb - DaniWeb IT Discussion ...
www.daniweb.com > ... > Hardware > Mobile and Wearables
The touch pad on my 10.1 inch asus memo pad doesn't work
Hoe long have you had this tablet? The fix may not be one that can be repaired without opening the case. But I would try a factory reset first.
With this problem, you will need to contact Asus.
2helpful
My touchscreen isn't responding
You have a Incopatible android version instaled in you pad or it is broked the touch screen try chage it vote please
1helpful
Cannot move cursor by touchpad. Can't shut it down either, since I can't go to start menu.
Try the following: 1. Check if the on/off button on your touch pad is turned on. 2. Restart the computer by pressing ALT+F4 until you get a shut down screen and then using arrow keys to scroll to restart. 3. If still not working, try reinstalling your touch pad drivers from the disk you got with your computer (connect an external mouse to do so, if not introduced to keyboard shortcuts). Good luck and please rate if something helps.
2helpful
2answers
Touch screen (which is EVERYTING) on m NOKIA 810 no longer works. Screen is visable but NOTHING responds to touch. Any options besides using it as a paperweight?
have you tried the soft reset yet?
take out the battery and let stand in freezer (put in plastic bag to keep out moisture) for 10 mins.
hold down the switch key wich is right above the escape key on the left side of the screen. and hold down the power button till she turns on. once you get the usb symbol in the upper right turn it back off and it should run like normal.
2helpful
3answers
My pen for my computer won't work
I think the pen has gone bad on you, since your screen can still detect your hand and the track pad. I would think the pen is faulty. Try another pen cause I think your original is bad, if it was the touch feature that wasn't working I would say its a driver problem but that feature still works with the exception of the pen. Get another pen.
Top Dell Tablets & eReaders Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Josh Lake
Are you a Dell Tablet and eReader Expert? Answer questions, earn points and help others
