Water Dispensing & Filtration Logo
A
Anonymous Posted on Sep 17, 2014
How to remove head off resin tank on culligan mark 89
How to take head off tank
Nick Tumolo
Level 2:
Sergeant:
  • Expert 245 Answers
  • Posted on Mar 31, 2015
Nick Tumolo
Expert
Level 2:
Sergeant:
Answers
245
Questions
0
Helped
81439
Points
545
It screws on to the tank. Make sure to relieve water psi. Turn the water off first.
  • 1 more comment
  • Anonymous Feb 28, 2019
    The fittings screw into the tank. The heat itself slides into the fittings from front to back. Unscrew the metal bracket from the head and the entire head will slide off the tank away from the pipes.
  • Scott Bass
    Scott Bass Oct 07, 2020
    How do you replace the resin in the tank? It has two pipes sticking out
  • Cam Smith
    Cam Smith Nov 14, 2020
    Any luck with removing the head on a mark 89 softener? Once you do how to access the resin?
2answers
Mark 49 Culligan softener what timer settings do I need to refill brine tank.
To set the timer on a Mark 49 Culligan water softener to refill the brine tank, you will need to consult the user manual for specific instructions. The manual will provide information on how to set the timer to control the frequency of regeneration cycles, as well as the amount of salt that is added to the brine tank during each cycle. If you no longer have the manual, you can contact Culligan or check their website for a downloadable copy. If the brine tank is not refilling enough after cleaning, it is possible that the brine tank float may be stuck or damaged, or the water level in the brine tank may be set too low.
My softener is a Culligan Mark 89. Water looks clear but is real salty. I bypassed the system and purged the lines to get rid of the taste.
Call Culligan for service. You have a serious problem as it sounds like your resin bed is not going through the backwash cycle before returning to operate mode.
Normally when your water softener goes through a recharge cycle, a solenoid operates to bypass the system while brine (extremely salty water) is drawn into the resin tank to perform the ion exchange process. This is a timed process. Once it completes then your softener switches into backwash mode where the resin bed is flushed with clear water. Finally at the end of the recharge cycle the softner switches back into normal operation.
This is not something that you can fix yourself. Contact Culligan immediately.
2answers
Need a seal kit for a Culligan Mark 89
Your local Culligan dealer is the only place to get one. You need the retrofit kit to prevent the shaft of sealpack from bending.
RJ
2helpful
Need a manual for a culligan mark 89 water softener, It's not a digital, it's a dial type settings.
Here is a the link for the MK 89 Use and Care Guide
http://www.isingsculligan.com/manuals/Mark89-812%287-97%2900881597.pdf
If you are looking for a parts manual that may be almost impossible as they are very protected.
RJ
Have mark 89 and water is going into salt tank, w...
That depends on what part of the cycle water is going into salt tank. If it is the last cycle (refill) it is normal until the proper water level is reached. If it is any other cycle then the brine piston or sealpack needs to be replaced.
RJ
Culligan 01010091 (mark 89) softener will not auto
clean the drainage filter then it will work correctly again
Proper Disposal of a Culligan Mark 50 Water Treatment Tank?
If you disassemble the valve completely (all metal parts) the valve itself is delrin plastic and is recyclable along with the brine tank. You may be able to scrap the softener tank. You will have to get all the resin and gravel out of it. Just tip it over take the inlet manifold out and drain the resin into a bucket, take the resin to culligan for disposal.
RJ
2answers
I have had salt in for 3 weeks culligan mark 89 is not recharging
If the unit will recharge then you might have what is called a salt bridge in the tank. The salt is stuck above the water level in the salt tank. Poor a gallon of water over the top of the salt and see if you can then break it up. The salt should go down then.
5helpful
The brine tank on my Culligan Mark 89 softener is leaking. Where can I get a reasonably priced replacement?
Most Culligan brine tanks have a lifetime warranty.
Check with the dealer for a free replacement tank first before buying one.
Top Water Dispensing & Filtration Experts
Larry
Dwain Schmidt
Dwain Schmidt
Level 1 Expert
Steve Pack
Steve Pack
Are you a Water Dispensing and Filtration Expert? Answer questions, earn points and help others
