Park the vehicle on a level surface. Start the engine and keep it running while you check and top off the power steering fluid. If the wheels are pointed away from center, turn the steering wheel so that they are pointed straight ahead.
Open the hood and locate the coolant reservoir, which is located at the front of the engine. Remove the screw that holds on the trim panel around the reservoir. Turn and lift the trim panel to remove it.
Locate the green cap with a small slotted extension on top of it. Insert a small screwdriver or similar object into the slot. Remove the lid by turning the tool and the lid counterclockwise.
Clean the dipstick on the bottom of the lid. Screw the lid back into the reservoir so that the dipstick goes into the power steering fluid. Tighten the lid until the arrow on the lid points at the first mark on the reservoir.
Pull the lid back out and see where it reads. If the line from the fluid is below the full mark, add Audi-approved hydraulic fluid (G 002 00) until the dipstick reads to the full mark.
Reinstall and tighten the lid until the arrow on the cap points at the second mark on the reservoir. Turn the steering wheel to make sure the noise has gone away. Reinstall the plastic trim panel around the coolant reservoir and tighten the screw.
W02 Car OBD II HUD ASH 4C Head Up Display 5 5 Inch Comprehensive Display
Does it do it just when you stop ?
SOURCE: growling noise comming from back of car.
Usually when people use the word "growl" it is a bearing problem. Try spinning each side with the tires still on so you have some weight on it. Also bearing will often change in volume when you do lane changes. However, the very first thing you should do is check the gear oil level in the differential.
SOURCE: is it possible to fit land rover discovery 2 wheel
is their any difference?? i would really need to get my hands on and around this to see whats what ,but i should think it could be done
