Gas fill crankcase and blow out muffer , engine runs but backfires check key on cranks is ok need to have choke pull out to keep running
if it has a fuel filter. check that. change the spark plugs.
SOURCE: Honda GX100 gas engine will not idle,
You will need to adjust the low speed idle screw. Make sure the spark plug is clean before adjusting.
SOURCE: Honda g100 stationary engine starts and runs well
Same problem here. I solved it by removing carburetor, removing float and valve seat and soaking in carb cleaner overnite. Blew out all the orifices with air and reasembled. Runs as good as ever!
Always turn gas off and run until empty, gas evaporates and leaves residue in bowl and valve.
SOURCE: My gas power washer will not start. I filled the
Will it run if you pour a small amount of gas in the carb? If so, it's a fuel supply problem. Most likely a stuck closed float needle.
